W124 w/shield seal channel repair?
Old 12-30-2014, 02:49 PM
dallas687's Avatar
E420
Does anyone know if there is a replacement part or a way to fabricate a new channel for the windshield wiper seal? This is the wide rubber, one-piece rubber seal that is located at the bottom of the windshield and passes under the wiper blade assembly (part # 124 824 0498). The rubber seal should "lock" into a plastic channel, but my plastic channel has mostly cracked and fallen to pieces. I know I could use some sort of mastic or windshield sealant to "glue" it down, but this makes future repairs, such as cabin filter replacement nearly impossible without tearing up the glued down seal. Any suggestions? Thanks!
Old 01-01-2015, 08:47 AM
blackice's Avatar
W124 E320 convertible 1995
My advice would definitely be to replace it by a used one in good condition or a new one.
I think, but this has to be certified, that all W124 have the same part. Precise your car VIN and model to be sure.
To be precise, are you looking for the rubber seal or the plastic mould under it that collects water?
Look at this page and select what is broken. Then see the number 124.... and try to find it on internet or order a new one.
http://www.mbpartsworld.com/showAsse...d%20windshield
Good luck.
Old 01-17-2015, 10:45 AM
optimusprime m1's Avatar
W124 260E
Dallas there is a gentalman on this forum parting out a 300 w124. the parts are the same as yours
Old 01-24-2015, 12:44 AM
autounion's Avatar
Many Mercedes, Mini Coopers, Mokes
There are two types, early and late with the pollen filter.
KJ in Oz
Quick Reply: W124 w/shield seal channel repair?
