1994 E320 transmission cooler line leak
Old 01-10-2015, 01:45 PM
Dead Reckon's Avatar
1994 Mercedes Benz E320, 1977 Oldsmobile Delta 88
My transmission cooler line is leaking below the alternator, it's made quite a mess, but the car hasn't lost any measurable amount of fluid on the stick. A few drops of this stuff looks like a catastrophic failure. Anyway, what are the options? It's leaking where the fitting joins, there appears to be a threaded line at the leak.
Thanks,
-Ben
Old 01-10-2015, 05:23 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Well if you are not concerned about the fluid loss then get some surgical gauze wrap the connection with gauze/duct tape and get on with your life!!
Old 01-10-2015, 05:28 PM
Because that's exactly the sort of thing I normally find done to cars, butchering... Thanks a lot for nothing. I never said anything about not being concerned. If I wasn't concerned, I'd just attempt to tighten it and hope it doesn't break.
Old 01-10-2015, 06:36 PM
Plutoe's Avatar
1999 E300TD
You can place a small amount of torque,but those lines rarely come loose---you simply may have to change the line and if you do one do them both!!---are the unions the banjo type or through the nut type??
Quick Reply: 1994 E320 transmission cooler line leak
