Still parking, car accelerates very strong
Old 02-26-2015, 10:57 AM
John99's Avatar
1995 E300D
Hi,
I have a 1995 E300D with about 250000 miles.
After some extreme freezing days the car didn't start. I changed the battery (new) and now the car starts better then before.
Problem: But 2/3 seconds after starting the car, still parking, accelerates very strong without touching the gas paddle. Then I stop the engine, start the engine and it's the same situation once again (repeating without exception).
Could be something with the injection system but I am new to this and I don't want to 'confuse' you.
Who had the same situation? What could it be? Which part?
Thanks in advance.
Old 03-05-2015, 04:19 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Sounds like you have a issue with one of the components within the vacuum system---find a engine vacuum system drawing for a 606.910 and start testing!!
Old 03-09-2015, 02:04 AM
hvguy's Avatar
300d
doesnt the 606 have the electronic controlled pump? could the computer just be freaked out? Maybe try unplugging the battery and let it sit for a few minutes and retry. Ive had a 05 is300 gasser do this when I unplugged a sensor. I reset the codes and did the battery trick and its back to normal.
Old 03-09-2015, 11:09 AM
Plutoe's Avatar
1999 E300TD
Nope-------last of the mechnical pumps-----forget the gasser HS you drive a diesel he may not know the difference!!
Quick Reply: Still parking, car accelerates very strong
