Need Help-brake light issue
Hello
I have a 1995 E420 that I have just purchased. Love the car, but it needs some love. Brake light issue- driver side, press brake pedal- 1 bulb lights up bright, passenger side - row of bottom three bulbs all light up dimly.
This is definitely not right. Is this a grounding issue? How can I fix it? Any ideas where to begin? Thanks for the replies and help.
Well on your new hidden rust bucket, with emphasis on rust, you will never no until you remove the lamp assemblies from the fender and trunk---look at connectors and bulb holders and be patient!!
Wow, super negative guy. I have pulled the light trays, checked and cleaned connectors, and checked bulbs. Ground looks ok, but something is shorting. Anyone know any common culprits? I checked the fuses at front of car as well. I am going to try and following wiring in the next couple days.
Well maybe like you did in post 3 ---finally told the complete story on what you have done to solve your problem we would not have to go the BS guess route
1 Post
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
If not that is a good place to start.
The rear tail lights utilize a light bar with a common ground. The strip is held in place by the plastic. Ensure that the light bar is completely seated. They can pop out causing a draw on the system.
Are you getting the bulb out light lit on the dash board?
Hello
