Help with a broken hood hinge..
Old 08-24-2015, 01:12 PM
Mylesph1's Avatar
1989 300CE, 1994 E320 Coupe
I bought a used '89 300CE from a friend that, with some time, has gone from having multiple little issues to being pretty solid.
The car suffered some mild hit in front in its life - not noticeable unless you really look. But the hood didn't latch closed when I bought it. I put a new hood on it and adjusted the strike plate and it would close, but the edge closest to the windshield always sat too high, and beyond the range of adjustment of the bolts.
So when the passenger side hinge broke yesterday I wasn't happy, but it made sense - the front arm pulled out of the slot, it won't go back in, and with only the one driver side hinge working the hood is WAY off center, so the car isn't drivable with the hood hanging sideways.
Enough of the story, the two main questions are;
1) Who has replaced a hinge on these?
2) Once I take off the fender, how hard is it to remove the hinge assembly?
Thanks in advance..
Old 08-24-2015, 02:41 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
The only trick is making sure that the spring holding bracket is pointing horizontal forward when the hood is closed!!
The alignment process is a bit tedious however if you have access to the WIS docs all will be clear!!
Old 08-24-2015, 04:14 PM
Mylesph1's Avatar
Okay so when the hood is in full upright service position, the arm is vertical like this...
So if you're saying that arm on goes horizontal when the hood is closed, that makes sense. I can't quite tell how that bracket is mounted to the body from this picture, you make it sound pretty easy.
Old 08-24-2015, 06:29 PM
Plutoe's Avatar
1999 E300TD
Yep it is easy--the alignment aint!!
Old 08-24-2015, 07:29 PM
Mylesph1's Avatar
I pulled the hood off once so I know that's crazy! Thanks..
Quick Reply: Help with a broken hood hinge..
