tire rubbing fender
Old 10-01-2015, 07:03 AM
ElieSednawi's Avatar
w124.031 300e 1991
tire rubbing fender
Hi
i have a problem with the front left tire.
the tire is rubbing the fender while cornering, intact the whole tire looks like it a bit out side the fender compared to the right side.
more information: the gap between the tire and the fender (left side) is more than the right one.
the car have sportline chassie
thank you in advance for your replies
Old 10-02-2015, 10:53 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Is this something that just happened or have you been driving the car like this since you purchased the car.
Old 10-02-2015, 12:33 PM
w124.031 300e 1991
since i purchased the car
Old 10-02-2015, 02:04 PM
thcdi's Avatar
s210 320 cdi avantegarde
first I would check the tyre sizes are the same,if they are the same size
make sure they are the same brand and model and have the same amount of tread left.
if you are happy the tyres are the same,i would then check the wheels are same
width and offset (et) ,this will be stamped on the back of the wheel and only visible by removing the wheel.
if everything looks ok wheel wise,you may have a suspension problem or the car could have worn shock absorbers.
Probably best you get it checked out by a reliable mechanic if you cannot see the problem
good luck
Old 10-04-2015, 05:02 AM
w124.031 300e 1991
good luck
thank you for your reply.
tires are new, same brand, all same size, Wheels the same.
shock absorbers are new as well, springs are new too.
i asked many mechanics for that, and it led me to change the springs, absorbers and bushing. all for nothing.
i even checked if the car had accident and fixed in a bad way but it is not, it even still have the factory paint both in the engine booth and underneath.
i will be adding photo's later on to show the problem exactly
Old 10-04-2015, 05:11 AM
w124.031 300e 1991
[ATTACH]tire rubbing fender-right.jpg[/ATTACH]
Old 10-05-2015, 05:24 AM
thcdi's Avatar
in the bottom picture the tyre looks nearly flat and the rim looks damagad.
Old 10-05-2015, 06:23 AM
w124.031 300e 1991
the rim was damaged recently (last Friday)
Old 10-06-2015, 03:17 PM
thcdi's Avatar
have you had an alignment done on the front wheels or tracking adjusted( same thing),
does it drive straight or shake through the steering wheel?
Old 10-12-2015, 08:51 AM
w124.031 300e 1991
All correct and the car go straight
Quick Reply: tire rubbing fender
