MB Noob: W124 TD Suspension Overhaul
BMW: '87 535i & '01 M5 MB: Searching....
Hi everyone I entered the MB world last fall with the purchase of an '87 W124 300TDT, and I've been lurking on the forums since. It has been serving me fantastically so far, but a season of Michigan roads has finally finished off the 160k mile original suspension and it is time for an overhaul.
I've been reading all of the suspension related things and think I have what I need to buy/do mostly figured out, but I still have a few questions. So here is my shopping list so far with some related questions. Please let me know if I've missed anything or gotten anything wrong. Hopefully this list can serve as a good reference for other people down the road.
Front End
-Control Arms (don't want to fiddle with bushings or ball joints so I'm replacing the whole thing)
-Tierods
-Centerlink
-Steering Damper
-Shocks (Not sure which Bilstein I want/need, but I'm looking for comfort over performance and stock ride height, for now)
-Shock boots and bump stops (will these come with the shocks, or do I need to order them separate)
-Strutmounts (One of my friends has a 190 and goes through these like they are going out of style. Which brand is the least likely to fail on me?)
Rear End
-Control Arms (Camber, toe, push, pull, & lower/spring)
-Bushing/compression sleeves (Where do these go? How many are there? Do they need to be replaced?)
-Carrier bushing (Will need a press tool, found a thread outlining how to make one with common parts)
-Hardware upgrade (I read somewhere that they changed the mounting hardware size for some of the suspension. What to I need to get/do to account for this?)
-SLS Struts (They currently work perfectly and don't leak. Is there any potential reason to replace them if they aren't leaking)
-SLS Strut Dust Boot (These are no longer existent on the car, has anyone had any luck replacing them with something aftermarket?)
-SLS Accumulators (Replaced them when I got the wagon, putting it here to show I haven't forgotten them)
Front End
-Tierods
-Centerlink
-Steering Damper
Rear End
I thought it might be nice to give an update on this project. I had half the parts ordered when last week something terrible happened. My wagon got hit by someone turning left when they shouldn't have. The insurance is calling it a total loss. So I am buying it back to sell to one of the local MB guys to fix or part accordingly. In the meantime I am looking for a new vehicle. I would like to either get another W124 wagon with OM603 or M104 or a W126 with M103 or OM603. Please let me know if you have any leads on one of these in good shape.
I also thought it might be nice to post up the updated parts list I made with part numbers.
Front
1243303007 Control Arm L
1243303107 Control Arm R
1243300803 Tie Rod L
1243300903 Tie Rod R
1244600805 Center Link
1244630432 Steering Damper
1244600119 Idler arm bushing
1243203030 Shocks
1243230192 Dust Boots
1243230744 Bump Stops
1243201444 Strut Mounts
1243235085 Bushing: Sway to Control Arm
1243234585 Bushing: Sway to Frame
Rear
2103503406 Camber Arm
2103504506 Camber Arm Hardware Kit
2103502153 Toe Arm
1403501170 Toe Arm Hardware Kit
2103503806 Push Arm
2103504506 Push Arm Hardware Kit
2103503306 Pull Arm
2103504506 Pull Arm Hardware Kit
2203520227 Carrier Bushings
2023520165 Control Arm Bushings
1243200489 Sway Bar Links
1243260581 Swaybar Bushings
N/A SLS Dust Boots
1243511342 Front Diff Bushing
1243527765 Rear Diff Bushings
1243500341 Front Subframe Bushings
1243510242 Rear Subframe Bushings
Other Rubber
1242401917 Motor mounts
1242400618 Trans mount
Front
1243203030 Shocks
Rear
2103502153 Toe Arm
2103503806 Push Arm
2103503306 Pull Arm
N/A SLS Dust Boots
Other Rubber
