vigorous Crankcase
Old 11-13-2015, 05:49 AM
mb-novis's Avatar
300CE 24v -92
vigorous Crankcase
MB 300 CE 24v-92
The crankcase ventilation is very vigorous and stop the Engine. If I take away the hose (the big one to the airfilter) from valve cover the Engine run fine but if I not take away the hose the Engine stop after 10 minutes. The Engine start only if I take away the hose again.
The kompression is very good over all 6. No oilconsume. Engine run very good, no other probleme.
People say there is a 2 mm hole in the intake pipe that can be filled. If the hole is stop it can be havy crankcase ventilation. Where is it?
Old 11-14-2015, 09:09 AM
mb-novis's Avatar
300CE 24v -92
Today I did a leak-down test. 30-50% leak from the piston rings?
Can I change the rings without take away the Engine from the car?
Quick Reply: vigorous Crankcase
