help needed: M103 vs M104 dsitributor cap and rotor dimensions.
hello people.. im putting a megasquirt on my 300e24, ( m104.980 Ketronic fuel injection ) i need to know if the dimensiones of the distributor from the the engines are the same, i mean if they are phisically compatible, distance between screws and all that, why i need this ? because of this
http://www.gptechservices.com.au/sto...el_system.html
its a kit mostly plug and play for a vr sensor using the original mounting of a m103 distributor and rotor.. so if its phisicaly compatible i can also usit, i already contacted the seller and he could not tell me if it work or not..
so if someone have information about that, ill be very helpfull
again. thanks. and cheers from argentina.
Billy the kid i can see by the part numbers they quote are not the same .
M103 Part number = 1235522384 M104 Part number = 1235522427.
So if they are not the same part numbers then the part is not the same.
Easy to do your self , just look the parts up on a mercedes parts site .
I found the following site very useful in finding parts as there are diagrams and part numbers shown against applicable model year and chassis (VIN) number:
http://www.mbpartsworld.com/
