Front passenger window stuck in down position
Old 06-14-2016, 11:06 PM
jjbendo's Avatar
1986 300E
Hi,
1992 300D, 110,000 miles.
First time out after not driving the car for 3 months, I lowered the windows, they went down fine. At the end of my trip the Front passenger window would not go up.
I swapped the two front window switches, Passenger switch installed on Driver side worked fine. Driver switch installed on Passenger side did not make the Passenger window go up.
Pulled the door card to investigate. How can I jumper the motor to test function?
See attached file, what are these wires?
Any other suggestions would be appreciated.
JJ
Attached Thumbnails Front passenger window stuck in down position-wires-under-door-card.png
Quick Reply: Front passenger window stuck in down position
