e320 sunroof problem!
Not an expert myself, but most likely one of the plastic parts broke and not functioning. Should be straightforward and not terribly costly replacement and repair.
Not with my MBs, but had a similar problem with my Porsche years back.
w/ smiles
Jimmy
w/ smiles
Jimmy
Sound like the cable has slipped, try take a look at the motor on the left hand side inside the boot. If it is not the cable then you can try manually turning the motor by wrench to close the sun roof first. There are many DIY resources on fixing the sunroof. There are also repair kit available on eBay.
I found the following read very useful; have pdf files on repair procedures too. http://www.benzworld.org/forums/w126...air-pdf-3.html
SPONSOR
We have a couple tech articles on this topic as well: http://www.pelicanparts.com/techarti...eplacement.htm
If you find that any replacement parts are necessary, you can find them in our parts catalog here: http://www.pelicanparts.com/catalog/...BDYSUN_pg1.htm
Good luck!
Good luck!
QVHK (07-08-2016)
