95 E320 wagon Noisey tandem pump
Old 07-05-2016, 11:11 AM
J MULLIS's Avatar
95 W124 WAGON
Question 95 E320 wagon Noisey tandem pump
Replaced the 1st pump with a good used one, but the noise persists. The steering seems unaffected, it works fine.The noise doesnt change when turning. The self leveling works as normal. By the way, contrary to some posted info that said the Vickers and ZF pumps are interchangeable that is incorrect as two of the fittings are of a different size.
Old 07-05-2016, 11:24 PM
QVHK's Avatar
'90 300CE M103 Manual '93 Alfa 164 QV24 '05 Jaguar X350
Maybe the used pump you bought is also nearing end of its life, or there is still a problem in the system somewhere. Knew that buying new is expensive, but can try re-manufactured ones which guarantee a perfect fit.
Old 08-29-2016, 06:03 PM
J MULLIS's Avatar
95 W124 WAGON
solved
It turns out that I was misled by a bearing noise in the belt tensioner.
Old 08-31-2016, 10:04 PM
QVHK's Avatar
Lucky that you didn't spend more on replacing the wrong part.
Quick Reply: 95 E320 wagon Noisey tandem pump
