HVAC part identification. HELP.
Old 07-26-2016, 10:05 AM
MacMade300's Avatar
'90 300E
I inherited this 1990 300E this weekend. It was my grandmothers. She didn't want to pay for the new part and had a mechanic bypass it with a toggle switch to turn the heater fan on in the winter. Can anyone identify this part on the top of the dash so I can find a good one to replace it?
Thanks in advance,
Rusty
Old 07-26-2016, 06:03 PM
MacMade300's Avatar
'90 300E
Bttt
Old 07-26-2016, 06:43 PM
MacMade300's Avatar
'90 300E
Apparently it's the blower resistor. I can get a new Behr OEM for $180 or a China made one for $30-40 on eBay.
Has anyone had any problems with the cheaper ones?
Old 08-05-2016, 11:18 AM
kajtek1's Avatar
Received 1,728 Likes on 1,378 Posts
1922 Ford Model T / no OBD
Resistor is resistor. Chinese can make good metals, but US market buys only cheap stuff from them. I don't hesitate to buy Chinese, but I check the feedback and inspect pictures carefully to see quality of manufacturing.
I tag along in the topic.
I am helping my father in his 1987 300DT and the blower is intermittent.
I searched the section and tons of blower topics, but most of them flooded by forum spammer and none of them come with good conclusion.
Father's blower comes on restarting the car, or sometimes few minutes into the drive on its own. Drives me crazy.
I replaced all the controls, file up ignition switch contact, check the plug behind brake booster and although now the blower comes all the time on my driveway, on last longer drive it died. I took it home and tested the fuse to have power.
Look like the mechanic above knew something about the issue and add additional switch.
I am tempted to do the same, but with heating module, where to tap the power?
Old 08-08-2016, 09:53 PM
kajtek1's Avatar
Follow up on my blower issue.
After dropping several parts and still having intermittent hang-ups I finally went for easy part.
Blower motor. It is easy part, but not so easy access, but having 5 cars on junk yard, I broke some parts on 1st and took me about 10 minutes to get to blower motor on 2nd one.
Old blower on father's car still has long brushes, but "somebody was there before"
Whole wiper assembly was hanging on 1 nut + the shape fit. Old blower motor had additional wires solder to it. My conclusion is that the wiring on commutator has to have dead loop or 2 and when it works on high most of the time, once you turn it to slow it will stop and not restart till some shaking.
Regardless the age, it is pretty complex system. The cabin controller sends signal to blower controller under the motor.
When you measure it on 3-pin plug behind master cylinder, slow speed is 1V, high speed is 9V and anything between on auto mode.
If you measure steady 12v on center pin and above voltage on right pin (looking from front of the car) that means your problem is on the motor, or its direct controller.
Now neutral safety switch was not that bad job, but extremely dirty.
Quick Reply: HVAC part identification. HELP.
