m104 oil leak
Old 12-01-2016, 11:23 AM
gang's Avatar
1
m104 oil leak
Hi friends, I have a 300e24 m104 and I have an oil leak, as far as it is common in this engine, I think it is leakage through the head gasket, I see it on the distribution tensor, I disassemble the upper distribution cover And seal with glue the "u" -shaped rubber gasket, and still have the problem, the leak is exactly where it is seen in the photo, Is this fugue common?
mbzusr (12-09-2016)
Old 12-01-2016, 11:30 AM
gang's Avatar
1
Is it possible to tighten the cylinder head again?
Old 12-24-2016, 01:11 PM
Celicasaur's Avatar
W212 - E63 AMG
No ^ sadly not. It's from the gasket, then it will need to be replaced unfortunately.
Old 12-29-2016, 07:10 AM
Anthony1406's Avatar
E280T
The U shaped should not be sealed with sealer! I did mine 4 times till it stopped. (the leak at the front by the timing cover)
While I was at it I did the headgasket also. Easy job but not to be underestimated if you do not have the basic tools/time/space. had the leak at the same place you did.
got a new one now somewhere but havent felt like finding it yet haha . I am done for a while
Quick Reply: m104 oil leak
