Help me determine correct color
Old 02-19-2017, 02:17 PM
MadeinFrankfurt's Avatar
1995 E320, 2008 C300, 2006 CLK350
I want to buy a rattle can of matching paint to paint the front license plate holder, which I just picked up from the local MB dealer.
When at the dealership the VIN details showed the color of my car to be Onyx gray. The build sheet I obtained says paint code 721 U, onyx gray.
I found a manufacturer (TouchUpDirect.com) who sells aerosol paint but their paint code 721 is referenced as Moonstone Gray Metallic, which seems to be much lighter than my paint color.
I am puzzled now as to the color code . My car is a 1995 E320.
Here my question. Is Onxy Gray also called Moonstone Gray?
Maybe I need to find a different source for a can of aerosol paint. Any suggestions as to a source for paint?
Old 02-22-2017, 11:18 AM
optimusprime m1's Avatar
W124 260E
You will be very lucky to find a spray paintin rattle can to match your car .Even more so if its a metalic paint . I had to send a part of ny car bodywork as a sample .Easy in my case as i had just fitted a new wing ,so i cut out a part of the old wing and posted it off to the paint company . End finish is out of this world, and spot on.. Wishing you good luck .. Your paint is 721 is right - onnx grey I find nothing for Moonstone Grey in my colour codes for mb.
MadeinFrankfurt (02-22-2017)
Old 02-22-2017, 10:39 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
How about you just take it to a paint shop and have them match it? Can't be all that expensive.
Old 02-23-2017, 01:10 AM
ohollenbeck's Avatar
04 E500, 00 SL500, 99 SL500, 94 E420, 92 500E, 92 500E, 92 300CE, 06 Lexus GX470
2 names possible
I have seen a couple of cases where the same color has two names, my 04 E500 is a perfect example. The EPC paint code is 359 I believe, Tanzanite blue, but the window sticker from the factory clearly says Capri Blue. I had the same questions and doubted the Capri Blue designation until I received the window sticker from the PO. So I would believe the EPC code, unless the car was repainted at some time, the colors should be the same or very close.
Good paint shops can match anything, the plate holder has very little showing to begin with.. good luck
Old 02-21-2021, 02:25 PM
chillysyrup's Avatar
GLC
Old 02-22-2021, 04:37 AM
Trevor Hadley's Avatar
mercedes w123 260e
paint
Originally Posted by chillysyrup
I have used Mercedes paint before itis like chalk from cheese and looks nothing like the right colour . Check out a body and paint repair shop and get a tin made up to match your car .
Old 02-22-2021, 05:29 AM
Chuck Steak's Avatar
W124 300D
In fact I've been told this by a paint shop. I gave them my colour code and they said there were three variants of it. Best way is to get the paint shop to match it from scratch
Old 12-31-2021, 04:49 AM
robfolland's Avatar
ML63 W166
W166 Auxiliary Battery information - MBWorld.org Forums
