Water Pump Removal & refitting (300CE)
Old 09-25-2004, 05:47 AM
rotis23's Avatar
Hi All,
Started to replace the water pump last weekend
Whats the best method - it seems as though I have to remove the PAS unit underneath before the pump removal - I'm having trouble.
Any advice?
Thanks for your help,
rotis23
Old 09-25-2004, 09:48 AM
rotis23's Avatar
The answer is to:
- undo PAS pump casting bolts 4 + 1 allen key bolt (central in casting)
- remove fan and belt drive
- remove final PAS pump support bolt behind belt drive
- allow PAS pump assembly to fall - supported by strut
- undo water pump casting bolts
- undo jubilee clips etc
- congratulate yourself on posting questions, cursing in german, finding the answers and then posting replies to you own threads.
Hope this helps someone.
rotis23
Quick Reply: Water Pump Removal & refitting (300CE)
