Intermittent wiper setting
'99 E320 4Matic Wagon
What would cause the intermittent setting on my wipers to only work intermittently? Sometimes when it is raining very lightly, the wipers work as expected when set on intermittent, but mostly they go back and forth constantly as if on the low setting.
Rain sensing option (grid on windshield top center-behind rear view mirror): "...When the rain sensor detected water droplets on the windshield, it would activate the wipers for a single sweep, then check again. If the sensor "saw" more drops, the wipers took another sweep. In heavy rain, they swept continuously."
Is yours working in contrary fashion?
I'm saying that there is essentially no difference between the intermittent setting and the low setting. Even when it is barely raining at all, the wipers sweep back and forth continuously on the low setting. Every once in awhile the intermittent setting actually works and the wipers hesitate between sweeps.
i dont have one on my 99, but my brother's 2000 is sitting in the driveway and
my experience is this: the metalized grid embedded into the top of the wind-
shield (level with the inside rear view mirror) is the wetness detect. On first
click of the switch, if rain sensor senses rain, it swipes. If not, it delays until
rain accumulates on sensor and it deploys again - swipe/swipe.
Raymond,
Go inside the car and feel the windshield at the area of the "grid" around the mirror. You will feel that it is something applied to the glass on the inside and in my estimation has nothing to do with rain sensing. I do see from the outside a little patch of blue in that area but can't get close enough with out climbing on the hood to get a good look at it. Perhaps that has something to do with it.
It's a mystery to me - still - but sure works well.
Brian
Brian
98 W210 Advantgarde
The round blue thing in the grid IS the sensor, not the grid itself. When it senses rain on it (presumably if its blocked), it tells the wipers to swipe. Pour some water over it with one click of the lever and you will see. Never tried putting something solid over it although I'm guessing it'll work too....but its not a good idea to activate the wipers without any liquid whatsoever so I'm not prepared to try.
rshoemaker, when u say "when it is barely raining", is the rain continuous or are you talking about drizzles? If it is light rain (a little more than drizzles), the sensor will still cause the wiper to work like it is on low, even tho it is set on intermittent. When the car is stationery (e.g. at the lights), the wipers should go back to normal intermittent operation under these conditions.
Originally Posted by bingoldsby
Raymond,
Go inside the car and feel the windshield at the area of the "grid" around the mirror. You will feel that it is something applied to the glass on the inside and in my estimation has nothing to do with rain sensing...."
on this board, someone else said it was the grid and I just took their word for
it. Wasn't curious enough to examine close up or climb the hood like Lt Columbo
would have, neither. Thx for the correction...B and W.
Maybe I should throw a new wiper blade on there and see if that make a difference. Perhaps the blade is leaving a stream of water in front of the sensor or something...
Defective rain sensor operation.
When I say "barely raining", I mean the kind of rain where you think you might have felt a drop of water, so you stick your hand out and look up at the sky. Light enough that the drops on the windshield almost disappear so fast that you don't need the wipers on at all. Under those conditions, I would expect the wipers to run intermittently, but they run as if set on the continuous low setting (most of the time). They do occasionally work the way I would expect.
