Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 06-11-2008, 10:02 AM   #76
Drives: 1997 E320
Tony, This a great instruction E-Mail. Could you resend the picture, IMG 0895.JPG. When I open it, it only shows the upper 1/3 of the picture.
Thank you for your help.
J Nolen
To remove this ad, register today or login if you already are registered!
nolen01 is offline   Reply With Quote
Old 06-11-2008, 08:06 PM   #77
Drives: A Pre-facelift W210
[QUOTE=nolen01;2876889]Tony, This a great instruction E-Mail. Could you resend the picture, IMG 0895.JPG. When I open it, it only shows the upper 1/3 of the picture.Thank you for your help.
J Nolen[/QU
thanOTE]
I got my part in today and couldn't view most of the pictures...could this be a temporary problem with the site...or the image files are currupted.
Does anyone know where I can fine the images...since Tony don't frequent this site anymore...thanks
__________________
Flat hood emblem | debadged | chrome trunk handle | clear side marker | E55 taillamp | Alpine HU | ZAM modified Depo Headlights |
d2Benz is offline   Reply With Quote
Old 06-12-2008, 08:42 PM   #78
Drives: 1997 E-320
There is another way to replace the blower motor regulator in 1996-97 W-210that doesn't require buying a new blower motor, regulator, air box cover and wiring adapter or buying a regulator for the W-140 and splicing it into the old wiring harness.
K-A-E make a blower motor regulator (resistor is their term for it) that is a direct replacement for the old style that is no longer available from MB. It is part # K-A-E 3.701.420. Although the base plate of the regulator is slightly larger and differently shaped from the original part the screw holes line up perfectly and and the wiring harness is direct plug and play into the original motor and chasis wiring harness.
I recently installed this unit in my 97' E320 and it works perfectly, in fact, I think the new unit blows a bit more air at the upper settings than the old one did. I removed the blower motor from the dash to make the installation but I think this unit could be installed by simply removing the underdash pad and the airbox cover and leaving the motor and blower fan installed. I found mine on eBay from All European Auto Supply
http://www.alleuro.com/
rander is offline   Reply With Quote
Old 06-12-2008, 11:15 PM   #79
Drives: 1998 E430
Mine went bad and I was having a whine noise coming from my motor, so I decided to replace the it with the redesigned unit. I got the motor, cover and resistor for $400. I put it in at halftime of the laker celtic game #5, and it works great! I was going to modify it but when I heard the motor I said "screw it" and got the new unit and man is it quiet, came with a one year warranty, that's what put me over the top on it. who wants to buy all my old stuff?...........j/k
azurE430 is offline   Reply With Quote
Old 06-13-2008, 07:46 PM   #80
I finally got to see the images, must have been problem with the website initially. Got mine fixed with the W140 part...Easy fix..now Air Blows but not coolin....My mechanic said, I have a leak in my condenser...
uhmmmmm....
I guess one more to go.
thanks Tony for posting that mod.
__________________
Old 06-19-2008, 01:57 AM   #81
Man, I'm stumped.
I bought the KAE replacement (140-821-8351); wired it up and soldered everything really nice but when I went to plug it in - it was "live", even though the car was off.
So I did some research and found one pther post which had the same issue - and the poster reversed the blue and black wire and it worked.
Sooo I did that too, and same problem - power to the blower even though the car is off.
So my problem is I'm getting power when I plug the harness back in, even though the car is off.
I triple checked everything - I mean it's a basic project; black to black, red to red, yellow to yellow.
WTF happened? 98 E320
JerryCurl is offline   Reply With Quote
Old 06-20-2008, 07:46 AM   #82
Drives: 1998 E320, 1993 Vette Coupe
Quote:
Originally Posted by 4XFORE View Post
Did any of you folks got this regulator from Deutsche Parts USA? They are selling one for $129.00. I need to do mine too.
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
I bought that one, received it in two days. Took longer to get the blower out of the car than it did to switch the regulator.
__________________
1976 280 - Blue on Blue
2012 Corvette GrandSport
HOWSER is offline   Reply With Quote
Old 06-25-2008, 09:29 AM   #83
As an update to my above problems - it was in fact a bad regualtor. The regulator was "Open" and when connected to the harness, it would engage the motor even though power was off.
So for research purposes -
If you wire the replacement regulator and the motor turns on when you plug in the harness (even though car and air power is off), you got a bad regulator.
Don'y try to re-wire it different or do any further diagnostics. Simply return the regulator for a new one.
Mine is all better now and blowing like a *****
Old 06-26-2008, 09:24 PM   #84
Drives: 1999 Mercedes E300 TD
Tony, Somebody help!
Hi there,
I have '99 E300 TD.
Blow mortor is weak, so I was hoping to use W 120 replacement regulator to fix the problem.
I got the KAE replacement part but when I took out the Blow Mortor Assembly, I found a Behr A210 821 15 51 regulator plate - see attched photo. I can't attched the replacement regulator!
What are my options? Any advice?
Thanks and regards
Dominic
Early W210 Blower Motor Regulator Replacement DIY Here...-blow-mortor-059.jpg
dominicchang is offline   Reply With Quote
Old 07-11-2008, 07:46 PM   #85
Drives: '09 CLK550 & '98 E430
This thread sure came in handy. Took my time and just got it done. $170 and some time is a whole lot better than $800-$1000!
Here's a picture of what's inside that regulator. That plus some wires hardly seems to justify the $170.
__________________
The low road is often a four lane expressway
Wadster is offline   Reply With Quote
Old 07-16-2008, 10:15 PM   #86
imrandy's Avatar
Drives: Mercedes E420 1997
Send a message via Yahoo to imrandy Send a message via Skype™ to imrandy
Thumbs up ebay part 1408218351
Firstly, special thanks to Tony who has saved us all money and stuck it to the dealer who quoted my $920$ to fix my regulator.
Below you will find the link to the part that was supplied to me for 89$ from Deutsche Parts...
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
I installed as above and the AC and fan worked perfectly. One important note; someone above made a remark about the slight humming noise their fan was making. I need to tell you mine made that noise as well which made me think maybe there was a problem with the fan (blower) as well. Needless to say, the blower works just fine and it was ONLY the regulator fix that solved ALL problems I was having. Feel free to contact me if you have any questions...
Thanks all...
Randy
imrandy is offline   Reply With Quote
Old 08-22-2008, 11:21 PM   #87
Fathead's Avatar
Drives: 98 E320
Send a message via AIM to Fathead Send a message via Yahoo to Fathead
Thumbs up Worked for me!
The DIY worked like a charm. After changing the regulator, and charging the freon, I damn near needed a hat, coat and gloves.
Thanks.
__________________
98 E320 debadged
E55 Avantgarde tail lights,
Chrome headlight rings
and trunk bar,
Sony Bluetooth car kit,
XM Commander ashtray install,
MBenzNL Command 2.0,
new style CD changer and
folding blinking mirrors w/ Euro glass.
Fathead is offline   Reply With Quote
Old 10-15-2008, 09:57 PM   #88
Drives: E320 Wagon
Smile Worked GREAT!
Thanks TONY, the DIY regulator fix works great. My son and I did it in under 1 hour. He had the fun job of squeezing under the dash between the seat and I handed him the tools. The soldering was a breeze as were the cool results!
Tim & Allen
Rhode Island
RIHarley is offline   Reply With Quote
Old 10-30-2008, 07:36 PM   #89
Drives: 1997 E420
Works!
Thanks!
Not being a DIY guy, I ordered the part, took the instructions to my shop and had them do the work.
Charged me an hour labor.
They were very impressed with the process and said they will offer t as an option to customers.
frank2001 is offline   Reply With Quote
Old 11-19-2008, 12:14 AM   #90
Eklass420Spt's Avatar
Drives: 97 E Klasse 420 Sport/ 90 Honda Accord EX
umm can someone help me here? i think i may have gotten a revised blower for the 210.
Click the image to open in full size.
my old blower assembly. has one connector
new blower assembly. has 2 connectors and a ground
part number.
can some one shed some light one this?
__________________
Eklass420Spt is offline   Reply With Quote
Old 12-28-2008, 07:59 PM   #91
Drives: E420
Thumbs up IT WORKED! Another satisfied customer :-)
Thanks Tony, you just saved me a ton of money - You da man!
I ordered the regulator from AutoHaus after the blower which used to only run at half speed finally gave up the ghost and stopped working all together. Since it had operated first at full speed, then for so long at half speed, and then finally wouldn't blow at all, it made sense that it was most likely the regulator and not the blower motor itself.
The whole process took me about an hour, but only because I got a little OCD on the soldering.
Thanks again! A forum is only as good as its members and this one is GREAT!
E4201stMB is offline   Reply With Quote
Old 01-10-2009, 09:54 AM   #92
Drives: MB E200 Kompressor W210
Many Thanks From Italy
Thank very much, with this DIY you have solved my problem with the blower regulator.
This is the power of the WEB and the Availability of person.
I can save a lot of precoius Euro's.
Best Regard
Magnificat
the_bud is offline   Reply With Quote
Old 01-20-2009, 05:52 AM   #93
RoLi's Avatar
Drives: w210 3.2 CDI
hey guys ! what about squeaky noise from vent on medium pwr ? where need to oil ?
__________________
w210 3.2 CDI performed by LIQUI MOLY, Chiptuning ~240 HP, ~570 NM.
DTM 2010
RoLi is offline   Reply With Quote
Old 01-24-2009, 07:53 AM   #94
Drives: Mercdes 1996 E320
Smile 1996 E-320 ELEGANCE
I have a 1996 E-320 ELEGANCE Registered on 01-AUG-1996 and have just changed the fan blower regulator (see pictures) you will need to grind some of the heat sink pins of to get to fit, also you will need to drill and tap a new hole for the new regulator,
Drill size is 3.3mm and the tap is a 4mm I replaced the torx bolt with an Allen bolt. (it seams to work ok)
Regulator came from www.worldcarparts.co.uk.
Early W210 Blower Motor Regulator Replacement DIY Here...-fan-unit1.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-fan-unit2.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-fan-unit3.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-fan-unit4.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-fan-unit5.jpg
skyrocket2 is offline   Reply With Quote
Old 01-28-2009, 03:53 PM   #95
Drives: 1996 e-320
Hey guys. This fix went perfectly. I used the KAE part from Autohausaz, at $170.oo.
Must be a run on that part since the price came up a little.
After looking over the old part I realized why it didn't last. The part was French made. Not only that, but the heat sink portion is nearly 1/2 the size of the KAE part (which is german).
Benz aught to know better that that.
Anyways, like another poster sez. "It'll blow yer hat off!"
This fix was on a '96' E-320. It got cold in the Chitown winters up here. Thankful I found this fix before I gave up and paid for repairs.
aardvark is offline   Reply With Quote
Old 02-03-2009, 07:33 PM   #96
Drives: 1997 E320
hey guys i was browsing last night and found this library in cincinati
J2cruz is offline   Reply With Quote
Old 03-05-2009, 09:30 PM   #97
Drives: 1998 E320 wagon
another option for blower regulator replacment
Quote:
K-A-E makes a blower motor regulator (resistor is their term for it) that is a direct replacement for the old style that is no longer available from MB. It is part # K-A-E 3.701.420. Although the base plate of the regulator is slightly larger and differently shaped from the original part the screw holes line up perfectly and and the wiring harness is direct plug and play into the original motor and chasis wiring harness.
I have a '98e320 wagon w/ the old style regulator. I purchased the part mentioned above from all european auto supply for $236+shipping. Their part # is 2108219951. It is KAE brand (3.701.420 is on the box). Looks exactly like roring's part from his repair(the last picture) with the plug from the original harness. Got it today and installed it in about 20 minutes(had removed blower earlier in the week) Doesn't get much easier than this and no soldering/splicing required. Blows like a champ. Thanks to tony and rander!
Wooly is offline   Reply With Quote
Old 04-05-2009, 09:58 PM   #98
Drives: '93 400E, '97 E420
Question for Hicks97
Quote:
Originally Posted by hicks97 View Post
Awesome article Tony. Thanks for posting it. My problem sounds a little different. My HVAC system is highly temperamental. Some days it doesn’t blow at all. Some days it only blows at full blast and no amount of button pushing will stop it except to turn it completely off. And some days it will warble fast to slow very rapidly. Do you think replacing the regulator will solve this issue? I’ve lived with it this way for 3 years and with winter coming the idea of not having heat some days is looking less appealing. I have a 1998 E-320 (W-210).
Hicks97...did you ever figure out what was wrong with your a/c? Was it the regulator like most everyone else or something else? I was reading the forum and never saw your fix. Please let me know. Thanks.
liebeskind
liebeskind is offline   Reply With Quote
Old 04-14-2009, 06:58 PM   #99
Drives: 1998 E300 Turbodiesel-drove for ten years/165k miles
I figure Dominic Chang has already figured this out, but I have his same type of regulator, in an E300TD manufactured in June 97 as a 1998 model. The car has 162k miles on it, and going strong except for an extremely weak fan. I'm hoping this does the trick. Just ordered the part (after buying the WRONG earlier version on Ebay) from Autohaus AZ. My receipt from them is for the following:
2108211551 Blower Motor Resistor/Regulator; Late Version with Female Connector Perhaps this will help someone avoid the problem I've had. Again, the regulator for a 1998 Model E Class Mercedes is pictured above in Dominic Chang's post.
HoldenBeachBum is offline   Reply With Quote
Old 04-18-2009, 08:55 AM   #100
Just Installed It...
Just put in the part from AutoHaus AZ, the curved plate with what they describe as a "female" connector. Blows great. Got sparks a couple of times while taking it out, though...I would highly recommend pulling the back seat and disconnecting the battery before removing the old one. My battery (positive side) needed an open end wrench in a metric size that I didn't have on hand, but I found the correct one in the trunk mounted toolkit in my little BMW convertible (!)
Tags
1408218451, 2108211551, 320, ac, blower, carolina, de, diy, mercedes, motor, north, part, pictures, regulator, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
