Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 05-01-2009, 07:38 PM   #101
Drives: e320
Talking Another happy customer
I just completed my fix today, and had my hat blown off. Can't thank Tony enough. My only addition to this forum would be that I was able to buy the w140 blower regulator for 79.65, including shipping and insurance. Chinese knockoff. On EBAY at http://cm.ebay.com/cm/ck/1065-29392-...m=110377359122
To remove this ad, register today or login if you already are registered!
rhogrogian is offline   Reply With Quote
Old 05-03-2009, 10:00 PM   #102
Drives: e320
this thread saved me.
apope1974 is offline   Reply With Quote
Old 05-10-2009, 11:33 AM   #103
Drives: e420
w210 motor blower
This worked well 4 me. I highly recomend doing this....it saved me hundreds, who knows, probally even more...thanks 4 the forum
cennilli is offline   Reply With Quote
Old 05-22-2009, 03:42 PM   #104
Drives: E320
I will be doing this tomorrow.
I will be happy to have cold air again soon!
aaronl is offline   Reply With Quote
Old 06-04-2009, 11:08 AM   #105
Drives: 1996 280e
Confused...
Hello. My blower has started doing next to nothing. I have always found the blower "weak", but now it is worse. I read this thread and found hope....
Then I did the "actual values" test referred to on page one, and suddenly the blower is responding again, and the values reported in the test shows between 0,8-6,0v. The blower is still weak though (like it has been since i bought the car 2 years ago). Is the test reporting what the control unit is directing or what is actually happening to the blower? It definately does not blow any hats off....
Any ideas?
Click the image to open in full size.Click the image to open in full size.
nikben is offline   Reply With Quote
Old 06-12-2009, 03:17 PM   #106
Drives: 1999 E320 1989 560SL
Hello folks-
Just spent a hot 45 minutes replacing the regulator with the KAE 3.701.420 regulator from AllEuropean.com. No wires to solder or cut. Most difficult part was the contortions needed to get between the seat and under the glove box.
Blows even better than before.
Tony, for the original post and the subsequent ones with additional info - thank you muchly! Saved $850+.
Steve
smlusci is offline   Reply With Quote
Old 06-12-2009, 09:14 PM   #107
Drives: E320 2000
Thumbs up Another Satisfied Customer
30 minutes and I'm the girlfriend's hero!
nugent is offline   Reply With Quote
Old 07-24-2009, 04:46 PM   #108
Drives: 1996 E300D
MB Birmingham quoted $1285 for repair .... followed instructions posted here (many many thanks) and saved $960!!! To the one who posted instructions with photos ... you are a very good man ... thank you. Also, thanks to Phil at Peachparts ...very helpful. I love this site!!!
msmith7894 is offline   Reply With Quote
Old 07-29-2009, 02:43 PM   #109
Drives: 2008 BMW 750LI, 1997 MBZ E320
Hello,
I have a 1997 E320 that no matter what speed setting the A/C is set at, it only sprinkles out the air. The air is cold but you can only hear psst..psst psst coming out. This look like the DIY that I need. Would taking it out be the only way i know that i need the fan regulator/blower motor replaced? ANd i would order the s-class part right?
havanajoe26 is offline   Reply With Quote
Old 07-29-2009, 03:13 PM   #110
Havanajoe-
Assuming that the blower/regulator in your 1997 is the same as my early 1999 that I just repaired, you can use the KAE brand part from All European ($249+/-)
You may be able to replace the regulator without removing the blower motor, but it is difficult and requires some contortionist moves to get at everything. For the few extra minutes it takes to remove (4 torx screws) and disconnect the blower motor and regulator, it is well worth it. You can then take your time to clean and seat the new regulator correctly.
For more details, see Tony's post above - it is very well done and the current iteration of the KAE regulators is directly plug compatible - ie I did not have to do any cutting/soldering.
Good luck
Old 08-07-2009, 09:05 AM   #111
Drives: 1998 e300
another satisfied user of the instructions here. Very easy, I went the cheap route and bought the regulator of e bay for $120 shipped. 1 hour project,
Mike
nozzano22 is offline   Reply With Quote
Old 08-25-2009, 04:00 PM   #112
sammouhali's Avatar
Drives: E280 1998
Send a message via Yahoo to sammouhali
Too close just need another boost
Hi guys,
seems that I have finally found the solution to my problem after all, what a great thread.
However, just need one more push. My blower is exacrly the same like Domic's. I have used Domic's photo and marked what I think is the regulator, can you please have a look guys and let me know? is it only that I have to remove the two screws and the to jacks (or connections) and just buy a similar one?
Thank you all in advance.
Sameh Eid
E-280, July 1998
Early W210 Blower Motor Regulator Replacement DIY Here...-blow-motor-060.jpg
sammouhali is offline   Reply With Quote
Old 08-25-2009, 04:13 PM   #113
Hello Sameh-
This does NOT look like the regulator that I replaced in my '99 E320. At a minimum, the screw locations are not even close to what I replaced, and the device in your pic is much larger than mine.
Steve
Old 08-27-2009, 04:43 PM   #114
sammouhali's Avatar
Drives: E280 1998
Quote:
Originally Posted by smlusci View Post
Hello Sameh-
Steve
Hi Steve,
I have dismanteled the blower cover and found that my blower is exactly the same as the one that I have posted earlier. Just removed the two screws and the two wire connectors. bought a similar one (Behr) at 95 USDollars. Thanks to the tax free country that I am living in. My AC fan is now blowing like Winter Wind.
I still having a minor problem though. While scrolling the fan speed wheel to speeds from 1 to 5, it jumps up and down a little, but I am now able to get all speeds. I assume that the control wheel needs replacement or may be cleaning. Any ideas
Many thanks to you and to everyone on this thread.
Special thanks to Tony.
This forumn is a great one.
Sameh Eid
Old 09-07-2009, 07:24 PM   #115
Drives: 1997 E320
I have a 2002 E320 and the blower refused to go on at all the other day. We were about to go on a trip, so we took out other car (1997 E320). Thanks to Tony and this thread, I had planned to do this fix when I returned and save $800 plus on the fix. However, upon returning the blower now works with no problem. Any ideas on why what would cause it to stop working and then start again after setting two days?
MBAficionado is offline   Reply With Quote
Old 09-30-2009, 11:16 PM   #116
Drives: e 300
Just fixed my 1996 E300 and used a china knock off from Ebay. Total cost was 114.00 Can. dollars. The blower fans works great now. Thanks for the excellent pics.
techtecher is offline   Reply With Quote
Old 10-01-2009, 07:17 PM   #117
sammouhali's Avatar
Drives: E280 1998
Quote:
Originally Posted by sammouhali View Post
Hi Steve,
Sameh Eid
Hi everyone,
I have also fixed the problem of the jumping fan speed; found out that my AC control unsit, the analog speed dial and the temerature dials, are completly malfunctioning. Replaced with a used one from the scrap for only 140 USD. Great deal knowing that the original new one costs 700 USD. The AC is now working fine.... I mean finally working fine.
__________________
Those who can "DO", and those who cann't "TEACH"
Sameh Eid
E 280 Model 1998, Classic
Imported from Germany to UAE in 2003, First user in UAE
Old 10-14-2009, 11:22 AM   #118
Drives: 97 E300
Help on the fix
This fix made the fan blow harder than ever but after replacing the regulator it kicked on as soon as I plugged it in and can not be regulated or turned off unless I unplug it.
Any ideas on how to trouble shoot this issue?
DeezelBenz is offline   Reply With Quote
Old 10-14-2009, 05:51 PM   #119
Drives: 1997 E-320
DeezelBenz:
The most likely problem is that the wiring connections are not correct. Go back to the original description and pictures of the connections between the new regulator and the old blower and be sure they are correct.
rander is offline   Reply With Quote
Old 10-15-2009, 10:10 AM   #120
Drives: 1996 E300D
Talking Tony Great thread!!! Bosch part comes with a new wiring harness for E class
http://www.allpartsexpress.com/searchItem.epc ask for Phil. I to thought I had this problem. but mine was the actual motor. the part I recieved from Phil at allpartsexpress.com came with 2 wiring harnessess one that looks the same as the splicing pictures the other was perfectly made for my the E class mid 90's Benz. my is a 96 e300d. I was impressed. Unfortchantly I have a short in the blower motor.
go to www.allwartsexpress.com paste the part # 1408218451 look for the Bosch product. it does not show both connector plugs but I have attached some pictures of what comes in the box. Bosch has made it with a clip at the regultor so you can use either wiring harness.
Thanks phil
Early W210 Blower Motor Regulator Replacement DIY Here...-image_060-1-.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-image_062-1-.jpg   Early W210 Blower Motor Regulator Replacement DIY Here...-image_063-1-.jpg
shballard7 is offline   Reply With Quote
Old 10-17-2009, 11:55 AM   #121
Drives: 2004 E320
Hi all, I have a friend that has a 2004 E320 and the blower would shut off after a little while of use and then she would have to wait a while to turn it back on before it actually would come back on. This sounds a little different then most everyone elses issues, but M.B. said that she needed a new blower and regulator.
So, would the S-class regulator possibly work for this year of car and do you really think that the blower would need to be replaced?
Thanks for everyones help.
sendreszl is offline   Reply With Quote
Old 10-18-2009, 01:34 AM   #122
sammouhali's Avatar
Drives: E280 1998
Since the blower works, stops and then works back again; then most probably it is not the blower, as it ultimately works. I believe this is your regulator needs to be replaced. Using the chasis number, you will be able to get your part from any MB dealer. Please let us know what happened next.. Thanks. Sameh
__________________
Sameh Eid
Old 10-18-2009, 08:36 PM   #123
Drives: 2004 E320
Thanks for the reply, that's what I was hoping. I ordered the regulator and I'll let you know if that takes care of it.
Old 10-21-2009, 09:20 AM   #124
Drives: 1998 E300 td
It worked GREAT!!! and it was easy! All for $73.00 on Ebay!
See link
usla1 is offline   Reply With Quote
Old 11-09-2009, 04:42 AM   #125
Drives: W210 220CDI 00
Do this also work for a 2001 W210?
*read before posting*
I see that I can just buy a new regulator... :-p
NorBeta is offline   Reply With Quote
Tags
1408218451, 2108211551, 320, ac, blower, carolina, de, diy, mercedes, motor, north, part, pictures, regulator, w210
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
