Can't remove rear license plate screws !
Old 05-25-2007, 02:07 PM
E430_4MATIC's Avatar
1973 280SEL 4.5; 2021 E450S4 Wagon
I am not having any success removing the rear license plate screws. After using some WD40, all four just turn continuously. I peeled back the trunk liner and see a female end which keeps turning and I'm unable to free the two.
Any suggestions?
Thanks!
Old 05-25-2007, 02:31 PM
E430-2001's Avatar
Dirt latemodel
on the inside , that you described it spining, is it a nut or plastic insert? Can you get a pair of pliers on it? maybe needle nose pliers ?
Old 05-25-2007, 02:44 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its a Metal Nut Cert...Just grab it with vise grips
One will need to replace the Nut Certs...
Old 05-25-2007, 03:30 PM
It's about a half an inch long and the two feel fused together.
Old 05-26-2007, 01:40 AM
ohlord's Avatar
Cool licence plate
Grasp the head of the screw with a pair of needle nose pliers and gently pull towards you, while doing this use the screw driver to turn out the screw.Use enough pressure on the screw to pull it, but not so much that you can't turn it.Should work
Ohlord
Old 05-26-2007, 07:26 AM
Thanks to the speedy and helpful replies here, we went to the dealer and bought 4 nut certs and screws, fifteen minutes before they closed for a 3 day holiday weekend
All's been soaking overnight with WD40. If that doesn't work, they'll be drilled out!
Thanks Mercedes, what a LOUSY design just to change a license plate.
Old 05-26-2007, 12:43 PM
OldNate's Avatar
1998 E320
That happened to me before as well. Inside the trunk, there are nuts that the screws screw into. Once you take out the screw, the nuts will drop inside the body inside the lining of the trunk. You must take off the lining, find the nuts, and then screw the screws back into the nuts while looking at both sides. It is a really bad design.
Old 05-26-2007, 12:57 PM
Lancelot's Avatar
'01 W210 E320 CDI
On my car one of them was totally stuck, so after removing the inner lining I just sawed it off using a fresh loose metal saw blade...
Old 06-26-2007, 12:53 PM
Mrhappy71's Avatar
E320 2000
Unhappy
How do i remove the liner. Cant seem to get the plastic pieces holding the liner off.
PS
i asked the dealer to do it and all they did was saw off the head of the top bolt.
Now i must figure out how to get this S^%T off so i can replace my license plate cover.(which only uses the top 2 bolts)
DEALERSHIP 1 hour away
Old 06-26-2007, 02:20 PM
lkchris's Avatar
'07 GL320CDI, '10 CL550
Screws to use are M5, i.e. 5 mm metric.
Problem probably caused by use of something "close."
Old 06-27-2007, 08:27 AM
vinceC's Avatar
2014 ML350 4Matic
The sockets are designed like a pop-rivet. They are inserted through the body and the inner part is compressed from the outside (like a pop-rivet), locking the socket to the body. The sockets have a hex where they fit through the body, so they should not turn. Obviously, the hex area is stripped out if the whole thing turns. Grabbing them from the inside should work.
If there are nuts or some other arrangement, they are not original. I had to make some on my 2000 C280SE after some ham fisted type screwed mine up completely.
Old 06-04-2016, 12:16 PM
vinsuz's Avatar
2007 CLK 550
This is what I love about this forum: no matter how esoteric my issue, someone else not only had the same problem, but posted it and had others with the same problem reply!
Anyway, I was able to get only one screw out with the vice grips -- the other screws broke off, so I had to drill out the remaining screws and pry out the rivets.
Here are a couple of tips: You only need to remove the Torx screw on the left of the plastic cover near the latch because the liner does have a hole for the one on the right (although you may have to loosen the one on the right a little to slide the liner out).
The plastic caps holding the liner in place are two parts. When you look at then top-down there are two concentric circles; using your fingernails pull up on the inner circle to extend it and the whole thing should pop right out.
Once I drilled into the broken screws I was able to pry up on the outer sides of the rivet in order to pull it through the hole.
From now on its nylon screws for me"
Old 06-22-2016, 07:04 PM
livetodrive's Avatar
2001 E-430 4-Matic
Yup, I had the same problem when I sold my W210 last fall. I ended up drilling out the bolts. The buyer watched all this, and was very patient.
Quick Reply: Can't remove rear license plate screws !
