cleaning polishing fog lights 96 e320
i've polished the headlights on my e320 and now the foglights look not so spiffy......from a quick look it seems i'll have to take them out from the bumper to clean or polish them - if they are the same type plastic and not glass........
before i go further - can anyone tell me if they're glass or plastique? if glass can i take apart the lamp fixture and clean the lens?
If plastic i suppose i'll remove them and polish as i did the headlights. I was hesitant to take sandpaper to headlights but following through to the polishing stage made me a believer.....
Glass mate!.. hahaha, you can remove the fogs from the car, oppen it removing the glass's from the plastic part, clean it very good and it would looks beauty again
Fabio Daniel
Fabio Daniel
thanks fabio....
it was well worth the hour on the first and ten minutes on the second!
I popped open the access panel, took the one vertical screw out and slid the light out the panel hole....three clips holding the glass to the housing were removed and i was able to properly clean the lenses......back together and even worked the wormscrew adjuster back and forth within its range to make sure it keeps working when needed......then of course i realigned the foglights since i had to play with the adjusters.....
thanks again....beautiful fog lights now....
