Timing chain?
Received 1,729 Likes
1922 Ford Model T / no OBD
Don't you have front bolt holding sprocket?
I hope you printed WIS for the job?
I worked all morning to make it go without success. There is nothing around the pump that could impair the process. the problem must somehow be internally. The 3/8" clearance that is showing is evenly all around. I hate to apply brute force for good reason. Thanks for coming back to me and wish that you or someone else reading this has an answer.
It is few years since last time I was pulling IP out, but you should see the pump shaft coming out of sprocket assy on the front?
If I remember it right, the assy is called "timing device"
You might want to google the name and check W124 sites as well as older pumps had the same design.
