Steering lock problem - please help
#52
Can somebody please help and send me the PDF instructions with the image to release the steering lock on my 95 S420, honestly I dont have the money to send my vehicle to the dealer to be fix. Thanks sjim816070@gmail.com
#53
STEERING LOCK
how can I view the diagrams, can you sen't to my email?
Thank you for your help!!
#54
Please Help me
#55
Hello everyone. I am new to this great hangout. Well I have the dreaded 97 E300d steering wheel lock. I have tried cleaning ign. Sw. With contact cleaner. Lubed with graphite steering wheel jiggle vibration to key and other methods no joy. What do you guys think about the esl emulators for the steering wheel locks that are supposed to unlock it. Before I try the drilling technique. Is there any other neat tricks ? Thanks All
#56
unlock ESL in 98 E320
I have 1998 E320 with bad EIS and locked ESL problem. Instead of towing the car to the dealership and paying a lot of money, i got a working EIS with a KEY and a ECU from 99 e320 Donor car. Now, i have to unlock/destroy the ESL on 98 model. Would anyone please tell me how to do it? If i need to drill and destroy it, please let me know where exactly to drill. Please send a DYI to Denis.Scales@gmail.com. Thank you!
#57
ESL resetter
Does anyone have an experience with ESL resetter sold on ebay?
http://www.ebay.com/itm/BENZ-ESL-Resetter-Erase-EEPROM-In-Old-Type-ESL-W202-208-210-/271270871994?pt=Motors_Automotive_Tools&hash=item3f290103ba&vxp=mtr
If you do, please share your experience.
#58
Hi, I live in greece, i did removed the dash. 1995 W210 with flatblade key, to change the heater, did it all ok. But i left steering column free, so after i installed everything back lock won't open. position 0. if anyone give me details how to repair it. savvasiliadis@mail.saabnet.com
http://s68.photobucket.com/user/savv...%20W210?page=1
#59
can't unlock steering, and get car to shift to neutral
Hi , I was wondering if I could get instruction to unlocking the steering wheel.
I am putting in my key, and the car is acknowledging the key in the ignition, but I can't turn the key to unlock the steering. Is there a bypass , or other?
I ask this because I believe I can get the key to turn if I could unlock steering. I think the key is not turning because when I originally switched off the car, the car never recognized that I had shifted it into "park" , and as such , it is treating it as though the shift is not in "park" .
I can't move the shift from "park" .
D
D
#60
2008 GL 320 CDI, 2000 E320, 2000 C230, 2004 Toyota Sienna
#61
D
D
If anyone has solutions or Jonssen's PDF, please forward it to me. Thanks again.
#62
I need this PDF too. Please help me out and send it to me if you have it. I messed up and pulled the ignition switch before turning the key to the 1 position. My steering is locked and I can't get the ignition to slide in all the way. Car is a C140 99'
#63
I am thankful for any help please I am a struggling single father, I am losing my job all because my car locked up completely unexpectedly. I am positive it is the anti theft pin locking up in my 1997 e320 (w210 chassis), as confirmed by a MB specialist.
If you could please send me the video and PDF or advice anything is greatly appreciated.
I know this is possible I've heard of multiple people disarming the lock. I just need to know the proper instructions. Also your way is the only I know without destroying my vehicle.
Thanks and again any and all advice is appreciated. Also if anyone else has this information please send it to me.
laurenswift123@gmail.com
#64
1997 Mercedes-Benz E230 Manual W210
Steering lock
hi could you send me the pdf file so i can find out how to release this i have a e-class 280 1997 e-mail address is john.w.mulligan@btopenworld.com many thanks
Kind Regards
Buks
#65
Can someone please send me the link to fix the locked up ignition on the 98 slk 230? please send to kimberly_joynt@yahoo.com
Thanks a bunch
Thanks a bunch
#67
Wheel locking mechanism pin solution..?
Hi guys,
I have a euro version E300 1996. I found a problem before i installed my switch.
The original switch is the green one in the sleeve, I have removed the whole assembly in Position 1. In Pic 1 you'll see the position that the wheel lock insert is in and it matches the Pins position in Pic 2.
In the Pic 2 " Green Switch" , u can see a pin that goes through the switch in the wheel lock insert in a vertical position, so that must be postion 1.
In Pic 3, you can see what holds the pin in that position.... the exit port of the switch or the switch itself.
Pic 4 shows you how I've assembled the new switch, but the PIN is not in the same position to enter the wheel lock insert. The switch's exit port came that way as if it was in Position 0. The key however stayed in Position 1 and I didnt mess with it.
How can i change or correct it, so that it matches the wheel lock insert?
#68
can you email me the PDF PLEASE
#70
#71
Would like. Pdf or video on how to reset tripped anti theft steering lock for my e320
#72
Yes im handy with tools and mechanical.
#73
please send me the PDF. Much appreciated. windjammer51@hotmail.com[/email]
don't you? if you've read the thread, you'll see this mentioned several times
and will understand why he may no longer be responding to posts in this thread.
#75
Hello can I have the PDF e-mailed to telakos@gmail.com my brother's w210 steering wheel is locked and they ask for a kidney at the dealership.
Much appreciated
Much appreciated
