97 E320 Engine Won't Start
Hello ladies and gents,
I bought a 97 E320 on February with 82k miles on it. I have put around 2.5k of mileage so far since I bought it. The car has a clean mechanical and accident history.
It has small problems like burned out bulbs, leak on powersteering fluid that causes noise, but this forum has helped me so far. However I have now come across the first problem that leaves me scratching my head, the engine won't start!
Yesterday I took my car and ride to Oklahoma City (I live in Stillwater, OK), with a total round trip of around 150 miles. I guess it is the first long drive with my beloved W210 in the hot summer day. Well I got back to Stillwater, and the car still restart smoothly on two occassions before I finally drive the car to go to work. After about 5 hours I got out of work and try to start the car, it cranks but the engine just won't start running.
When this first happened just before I took out the key to try to restart, I saw a red sign on my odometer that says "+ Battery Charge -" (or something to that effect), and then ABS and ETS light turned on. So this promptly make me think that the battery is the problem. On the consequent occassions though, that Battery, ABS, ETS sign will never appear again.
So then I asked my friend to give me a jumpstart by following the manual closely but the car still won't start. So I left the car overnight at my work and today took out the battery and brought it in to Autozone for a battery check. The battery tester machine deemed it is a good battery.
So this is where I start scratching my head lightly. Next thing I do was checking the fuses and they all seemed in working condition. I have a limited knowledge of automobile in general, so I have come to a dead end. What else could it be guys? The starter solenoid? Fuel pump? CPS?
Please direct me to do DIY check ups so I can eliminate possibilities one by one and come to the main problem. I am sorry if I make this post too long, but I really want to get as much detail as possible. Looking forward to all your responses..
Thank you
Thank you
I will try to run the codes tomorrow and see what comes up.
I actually thought of that but haven't go through it yet. I will try checking on them this weekend when I have more time. However a bad alternator will usually light up the service engine light doesn't it? When the key is turned to mid position all electronics function properly, be it radio, power windows/roof.
**UPDATE**
So I tried to start the car today but first of all before I fully crank it I cranked it just for a second, pulled the key out and start it again (normally). And you know what? The engine starts!
But it was shortlived for like 5 seconds, and consequent attempts were not successful. I have a gut feeling that it has something to do with the fuel isn't fired properly to the engine when I start the car with the key.
Anybody probably can narrow it down more with all the symptoms that I have so far?
Thank you again guys..
Lacking a CEL usually narrows these things down to either batt voltage, supply (K40 relay), DAS (ign/key), or the CPS.
The fact it starts, then dies suggests the CPS is in complete failure mode rather than its usual intermittent fault phase.
I will look into it more tomorrow, thanks for all the response guys. If anybody wants to add a piece of their mind into my problem please do!
Thank you
zanna, I had an identical problem on my Nissan pathfinder. It took my mechanic almost 2 months to figure out what was wrong, the car had no fault codes, had spark at the plugs, fuel pump had correct pressure meaning everything checked out but the car would only startup for maybe 2-5 seconds then die again. and just like you it worked perfect until the moment it just stopped. (BTW... the car started every time when my mechanic hooked up an external fuel source to bypass the fuel pump...strange tell me about it ;-))
... long story short the problem turned out to be a bad distributor, something within the distributor sends a signal back to the COMPUTER that tells the fuel pump to send more fuel well this function would stop the moment the car started causing fuel to be cut. the car always passed the self diagnostics but the distributor failed to actually work like it was supposed to.
Again, i dont know if my nissan scenario is at all comparable to mercedes... i just wanted to share one my strange experiences which hopefully will help you find a solution for your problem
Sunny
Sunny
