Flashing low fuel light?
Old 01-23-2002, 10:20 PM
PetersE55's Avatar
2001 E55, Silver/Charcol
That's odd, I noticed my low fuel light was flashing on the way home from work tonight. What's really odd is that I have a half a tank of gas in it and when it is really low the light usually just stays on. I got home and turned the engine off and restarted it and it doesn't flash anymore. I checked for a malfunction message via the computer and none were reported.
I'll see if this happens again tomorrow. Anyone got any ideas as why this happened?
Cheers,
Old 01-24-2002, 12:26 AM
Hal H's Avatar
2001 CLK320
check to see if fuel cap is on tightly
the flashing low fuel light will occur when the cap isn't sealed up properly to the filler.
This is designed into the ODB-II emissions systems. If this goes un-attended, it will cause the "check engine" light to go on as well.
Shut engine off, remove fuel cap...
reinstall fuel cap and turn until it clicks. After the engine is re-started the light should go out shortly.
Old 01-24-2002, 10:20 PM
PetersE55's Avatar
Re: check to see if fuel cap is on tightly
Thanks Hal,
That's exactly what it was, unfortunately the "check engine" light did go on and I ended up calling the dealer. They told me that the light should turn off in a few days or I will have to take it in to reset the computer. I'm glad it wasn't any serious.
Cheers,
Old 12-14-2005, 04:30 PM
Monster's Avatar
CLK 320
Hello, I had this happen and resetting the cap didn't work.
I took it to the dealer and they replaced a senser. It's been a month and the light started flashing yesterday. I will let you know what happens.
Old 10-29-2009, 06:03 PM
colliegrey's Avatar
E420
I used regular gas and had the same problem, I switch to premium w/ one gas treatment and my problem was solved!
Old 10-30-2009, 02:01 AM
dylokjai's Avatar
00_e430_sport
why would you put regular fuel in your tank when the owners manual states premium octane?
Quick Reply: Flashing low fuel light?
