Fuse location for E320 1996 Trunk light??
OK, I have checked the manual, the 3 locations for fuses (under hood, side of instrument panel and under rear seat) and cannot find the fuse location for the trunk light.
Can anyone help me out?
1 Post
2000 E 320S4 210.282 4Matic Estate
It's probably not the fuse
According to the fuse chart and picture from fuse box, it's fuse No. 3. As you can see, this fuse also protects the dome lights, outside mirrors, power windows, etc. If all these are operating, then you should look at the light bulb. Hope it helps.
Cheers
Cheers
That was it!
That was the problem! The dome light was off as well which I did not notice at first. I really appreciate your help as the fuse diagram was not that specific.
