Fuse location for E320 1996 Trunk light??
Old 06-21-2009, 10:36 PM
Airetime's Avatar
OK, I have checked the manual, the 3 locations for fuses (under hood, side of instrument panel and under rear seat) and cannot find the fuse location for the trunk light.
Can anyone help me out?
Old 06-22-2009, 07:31 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
It's probably not the fuse
According to the fuse chart and picture from fuse box, it's fuse No. 3. As you can see, this fuse also protects the dome lights, outside mirrors, power windows, etc. If all these are operating, then you should look at the light bulb. Hope it helps.
Cheers
Attached Thumbnails Fuse location for E320 1996 Trunk light??-fuses_rear.jpg
File Type: pdf
Old 06-22-2009, 08:13 PM
Airetime's Avatar
That was it!
Cheers
That was the problem! The dome light was off as well which I did not notice at first. I really appreciate your help as the fuse diagram was not that specific.
Quick Reply: Fuse location for E320 1996 Trunk light??
