HELP!!! Shifter stuck in PARK
Old 08-03-2010, 11:03 AM
heaven2010's Avatar
2002 E-Class 320
gear shift stuck in park
Thanks for responding so soon. Yes, my windows and pretty much everything is working. I did check my brake lights and they are not working. I will go and replace them and see what happens. I am female and don't want to disassemble the shifter because I don't know how. I'll follow your instructions and keep you posted.
Thanks,
heaven2010
Old 08-03-2010, 11:08 AM
heaven2010's Avatar
2002 E-Class 320
Thanks for responding so...soon. I did check my brake lights and they are not working. My windows and everything else is working. I will do as you suggest to repair the brake light switch and keep you posted. By the way, where do I find the break light switch.
Old 08-03-2010, 12:43 PM
saintz's Avatar
GL450
The issue is the switch itself, which is under the brake pedal. You can find directions here to change it:
https://mbworld.org/forums/w210-amg/...s-bas-esp.html
The shifter is pretty easy to disassemble. If you take it to a dealer, they are likely to tell you to replace the whole module, which is very expensive. You may be able to salvage it, or find an independent shop that can help.
To check it out, use your fingernails to pry up the black trim ring around the shifter (near where it says P, N, D). Then open the ashtray and pull up on the wood console and the whole thing will pop out. From there you should be able to remove the shifter and disconnect any wires.
Old 08-11-2012, 12:51 PM
texholdem's Avatar
1996 E320
My 1996 E320 does not have the secret hole and the shifter gets stuck in P, in the picture it appears to be in R because the cover is moved forward.
The shifter is blocked in P position by a hook, which is released by a cable, which in turn pulled by the brake pedal. The situation now is the cable does not release the hook
My temporary fix is removing everything around the shifter housing (the whole middle console including air vents to the rear seats) to access the hook and make it permanently open, meaning the shifter is now moving freely in all positions until the problem is tackled.
Certainly I have to fix the problem but until then my questions:
1. is the brake light switch the cause that the hook releasing cable is not pulled by the brake pedal or is it a mechanical problem?
2. can I drive (relatively) safely with the hook now always open/disabled? Of course I have to make sure when starting the engine that the shifter is in P.
Your inputs are greatly appreciated, thanks!
Old 08-13-2012, 07:54 PM
texholdem's Avatar
1996 E320
I can't find the brake light switch for my 1996 E320 at autohausaz dot com, does my car have one at all? anyone has the part #?
Still waiting for inputs on my questions in the post #29 above, thanks!
Old 08-14-2012, 06:23 AM
renault12ts's Avatar
W215 CL500 2005
Try looking under the dash for one. If there is one, take it out, read the part number.
Old 08-29-2012, 06:19 PM
  #32
autotechusa's Avatar
BMW X5
That's a popular situation happening on Mercedes. I do have some repair kit which applied to that case. Plastic and aluminum ones and different sizes cover most of Mercedes Cars. Anyone interested can email me autotechusa@gmail.com.
Old 09-03-2012, 06:27 PM
  #33
DonaldBH's Avatar
SL500
I have a 2003 SL500 and had the broken plastic piece problem. The shift started out just occasionally sticking and got worse until I got stuck in a parking lot. I live in San Jose, CA and can recommend MiD Auto Services in Sunnyvale. AAA towed it for me (slid it up on a truck bed) up to MiD. They fixed it for me pretty quickly at a good price. They removed the error codes and it works like new now. I recommend them.
Don
Old 09-04-2012, 07:33 AM
  #34
Melba4599's Avatar
BMW
lucky me...indeed was the brake switch.
Old 03-28-2013, 07:16 PM
  #35
signguy15a's Avatar
2001 e320 4matic
stuck in park changed brake switch still no work
my e300 4matic died yesterday i changed the drive shaft sensor it ran fine for a test drive coming off the highway i downshifted to 4th and heard a clunk pulled into driveway and now its stuck in park changed brake pedal swtch and still stuck in park dont really want to have it sent to dealer no $$$ any ideas anyone
Old 10-18-2013, 10:32 PM
  #36
robingaton's Avatar
e320
same
Hello i have the same problem on my e320 i dont know that is the problem can some one help?
Old 10-19-2013, 01:32 AM
  #37
raymond g-'s Avatar
99 E320
if you have the same problem (unable to shift out of PARK), you need to give
us more details. did you read any of the suggestions in this thread? did you
try anything?
Old 10-19-2013, 09:16 AM
  #38
Beverly Sharp's Avatar
E430
shifter
No-one answered TxHoldem's question, namely, if he "disables the parking hook," can he drive the car safely? I would think there was no problem doing that (my older MBs didn't have a parking lock), but I don't know. Anyone?
James
P.S. If it would be safe, I'd be tempted to disable the thing permanently ('96 E320) just to avoid getting stuck in the middle of nowhere with a transmission locked in park, and no tools to take the shifter "thingie" apart in order to get home.
Old 10-20-2013, 09:32 AM
  #39
E430
shifter lock
Anyone know for sure?
Old 10-20-2013, 09:39 PM
  #40
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
The problem is that the parking brake interlock is only engaged when the key has been removed and the brake not engaged.
Plus the park interlock can only be released by turning the key to position 1 and pressing the brake pedal.
Suggesting to remove the cable or cut the cable would be a very foolish endeavor
Old 05-02-2014, 12:41 AM
  #41
henry1897's Avatar
2004 c320
Stuck in park
Originally Posted by raymond g-
shift unlock
Does the pen trick work for the 04 c320?
Old 05-02-2014, 09:01 AM
  #42
E430
shifter
There is NO place for inserting a pin into the shifter mechanism on my '96 E320.
Hemersam
Old 05-02-2014, 02:19 PM
  #43
Plutoe's Avatar
1999 E300TD
Henry1897 is having a senior moment---there is no pencil in the hole thing for the W210's shifter!!
Besides this post is seven months old and henry has just now responded!!
These symptoms typically occur because of a faulty key, brake light switch, ignition switch or gear selection switch!!
Old 05-02-2014, 04:20 PM
  #44
raymond g-'s Avatar
99 E320
henry, post or search for an answer in the w211 forum and perhaps there is
enough of a difference that will provide you with a response. r-
Old 04-18-2016, 06:41 PM
  #45
Et1010's Avatar
2003 mercedes clk 320
I've tried everything. HELP!
I have a 2003 mercedes clk 320 and the other month is when it got stuck in park. I was driving it up a small hill when it locked into 3rd and would downshift or anything. I pulled over and it locked into park. Now it's in limp mode when I use the pen trick. It's stuck in gear. Stuck in park. And I've charged the batteries, replaced the brake pedal switch. What else could go wrong. No drinks have been spilled into the gear box that I know of. I looked at it and it seemed fine no stickyness or anything. Also the bake lights were on on the dash but turned off now the only thing thats on is check engine light. What could the problem be?
Old 08-03-2017, 09:06 PM
  #46
joshsmomjulie's Avatar
2000 c230 kompressor
Help to Single Mom Please
I am having problems with the car I bought my son. 2000 C230 Kompressor. I had the dealer make a new key as we lost ours and now the key turns but won't crank the engine. My friend had me turn the key on for like 10 minutes and now it will start but won't come out of park. I stuck a screw driver into the release and i can get it out of park but now the car will not shift out of 1st gear. I did switch the battery so now I am totally clueless on what to do.
Any help? Please?
Old 07-13-2019, 05:21 PM
  #47
Michel255820's Avatar
e320 w210 and E500 W211
to the OP: any spilled liquid onto the shift/console recently?
Raymond : just curious,
I have similar problem (Stuck in P) and suspect it could have been spill on central console.
This is for E320 W210 year 2000.
I am looking at replacing the batteriy that is old, and replacing brake pedal sensor,
but reading your comment, I wnder if you can suggest another better solution ?
Thank you for you help
Michel
Old 09-01-2022, 01:59 PM
  #48
Kathio1957's Avatar
2013 E-63 AMG
Similar issue but my shifter is stuck in Neutral.
Car started running rough a couple days ago. Warning light said Auxillary Battery Malfunction - see owner manual.
Next warning when I pulled in driveway was Check Coolant and Check Engine Icon was on. Turned the car off and it has not been moved since. Yesterday after downloading, then studying almost all of the 420 something pages in the Owner's Manual frontwards, backwards and sideways I felt confident enough to go get coolant and motor oil with the guidance of the very knowledgeable guy at the counter of my local auto parts store. Followed instructions completely to add both (both fluids were very low). Did I mention I have not had car very long? Lol. So I was so excited to start it up and have all those warning lights be gone but instead I got nothing except - my battery is dead and I cannot start the engine! I don't know how I drained it but I know from reading in the manual that it is not recommended jump starting from another vehicle. What has me even more stumped is that after shutting car off and locking it I discovered the brake lights were on but only on the driver's side. So I used my key fob to open the door and double checked that everything was off. Closed and locked it and no more brake lights so I went inside. Today my stepson came by and he tried to start it - nothing except the arms on the clock started spinning around and wouldn't stop until he turned off the car. He locked it and we started walking away and noticed the passenger side back window is all the way down. We never touched the window buttons. I'm starting to think my car is possessed. Any thoughts or insights would be much appreciated. Thanks everyone for any help you can give. Kathi
Old 09-01-2022, 10:46 PM
  #49
raymond g-'s Avatar
99 E320
Originally Posted by Kathio1957
Car started running rough a couple days ago.....
Your 2013 car is a decade newer than the w210 forum you've posted in. You may want to repost within the proper forum so that owners with similar models can share their insights
Quick Reply: HELP!!! Shifter stuck in PARK
