FYI: W210 Fuse Cards
Old 03-25-2010, 06:25 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
For anyone interested here are the three fuse cards normally found in a W210. You will probably not have all these fuses. Those without a card can print them out. They are in pdf format for those of us who need to magnify them.
If you need a pdf reader, go here:
www.adobe.com/products/reader/
Attached Thumbnails FYI: W210 Fuse Cards-fusecard01.jpg   FYI: W210 Fuse Cards-fusecard02.jpg   FYI: W210 Fuse Cards-fusecard03.jpg
File Type: pdf
File Type: pdf
File Type: pdf
thenothingblack (06-28-2022)
Old 03-26-2010, 06:26 AM
anabase's Avatar
2001 E320 4matic sedan
Thank you for this.
Old 04-26-2015, 02:13 PM
goldy-40's Avatar
Mercedes-Benz 320 CDI Avantgarde Break
Voici un plan de ma carte de fusibles située sous le siège passager arrière
Pour Mercedes 320 CDI 01/2002 T Combi (sous sièe arrière)
Old 04-26-2015, 07:50 PM
RichardM98's Avatar
Thanks for sharing. I should probably add that the images I posed are MY1998 and as new features were added on the facelift models new fuse designations were needed.
Old 06-22-2015, 10:44 AM
Rob Roten's Avatar
2002 C320, 2002 E320
Thanks for this... Does anyone know which relays do what in the underhood fuse box?
Quick Reply: FYI: W210 Fuse Cards
