2000 E320 tiptronic shift?
Old 03-28-2010, 04:46 PM
mike62's Avatar
2005 E320 4matic wagon
Shifter question: Saw a 2000 E320 4 matic for sale. The shift selector had P,R,N,D1. and a switch at the upper left corner of the shift console. Couldn't tell what it was, curious if that could be a tiptronic transmission. Ever seen that before?
Old 03-28-2010, 06:04 PM
raymond g-'s Avatar
99 E320
tiptronic feature, but the switch isn't what trips it. driver simply taps the
shift knob/lever left (shift down) or right (shift up).
Old 03-30-2010, 09:18 AM
tmaguire's Avatar
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
The switch is for selection of Winter mode (W) or Sport mode (S). Basically winter mode starts in 2nd gear....
Old 03-30-2010, 10:13 AM
Figuero's Avatar
2002 E430 4MATIC
Keep in mind MB does not use Tiptronic. What they do provide is a more convienient way to move the gear selector electronically. However, you are not really manually shifting in the same sense as Tiptronic does.
Old 03-30-2010, 03:00 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
It is a tiptronic shifted transmission in the 722.6. The shift selector modes are winter (W) or summer(S). W mode starts off in second gear and changes the shifts points for better winter traction. S mode starts in first for normal fair weather traction and driving.The tranny adapts to your driving style on an ongoing basis. If you shift aggressively it will remember your driving style. To downshift tap the shifter left and to go up a gear tap to the right. You can hold left and it will run down to the lowest gear in W mode 2nd and in S mode 1st.
Old 04-02-2010, 01:06 AM
Figuero's Avatar
2002 E430 4MATIC
Actually our transmissions are not Tiptronic. Nor are they licensed variants of tiptronic used in cars like VW and Audi. Ours are Touch-Shift which essentially offers an electronic way to move the old gated shifter. It does not offer the true gear selection capability of Tiptronic.
For example, if Touch-Shift displays "3" it means you will automatically shift through the gears but it will lock out gears above third. Whereas, if a Tiptronic displays "3" it means you have manually selected third gear and in fact the car is in third gear.
Also, if you hold the Touch-Shift to the left, it will only downshift to fourth gear if you are in fifth. Otherwise it will simply display the gear you are already in, until you slow and stop the car at which point it will display 1 or 2 depending if you are in S or W mode. That is, if you are accelerating from a stop light and are in third gear, if you move and hold the selector to the left, it will display 3. It will not go to 2, or 1 until you slow to a stop.
Quick Reply: 2000 E320 tiptronic shift?
