A/C problem 98 E320
Old 07-16-2012, 01:55 PM
jimchilders1's Avatar
98 e320
A/C problem 98 E320
I'm having an a/c issue a new compressor has been installed and the clutch won't engage I was told as long as the EC light is on it won't i've tried the self test but the display is bad and I can't make out what it is reading. I've tried to reset it and it won't I was wondering if the controkl unit could be bad.
Old 07-16-2012, 02:38 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You are correct, if the EC light is on because of a fault the compressor will never start. If I were you, I would do the process again and at the end "clear the faults" surely you will see the FF.
Once you clear the faults the EC lamp should go out and the compressor should come on, however you have to find out why the EC light came on(no refrigerant maybe or bla bla bla) because it could very well come back on!!
Old 07-16-2012, 02:59 PM
98 e320
i've tried to reset the fault codes but i doesn't thats why i was wondering if it could be the control unit because you can't read the display
Old 07-16-2012, 04:45 PM
Plutoe's Avatar
1999 E300TD
Do me a favor, read the instructions again and preform the fault test one more time thanks!!
Quick Reply: A/C problem 98 E320
