Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Sponsored by : My Mercedes Parts
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-19-2010, 12:28 PM   #1
hpilot's Avatar
Drives: 2000 E320
Shoulder Harness Squeal
My driver's side shoulder harness makes a loud squeal every time I move it. This happened several years back, and I had it replaced under warranty. Nobody wants to repair it, all they will do is replace the whole unit at great cost. They are all afraid of liability. Is there any quick fix I can make to stop this squeal? It drives me nuts.
To remove this ad, register today or login if you already are registered!
__________________
2000 E320
White
Kenwood DNX 8120
JL 10" 250 Watt Sub
HCE-C105 Rearview Camera
JL Audio Slashv2 300/4v2 Amp
HD Radio
hpilot is offline   Reply With Quote
Old 06-20-2010, 12:28 AM   #2
raymond g-'s Avatar
Drives: 99 E320
never had to open one up on a 210 so i have no advice for you. no guesses
either, since origin of noise is difficult to pinpoint over the internet. chances
are good that as a DIYer you'll have to open up the liner to the B column. i
would hate that because that's a lot of labor. I'd rather change motor mounts.
no TSB found
ALLDATA Online - 2000 Mercedes Benz E 320 4MATIC Sedan (210.082) V6-3.2L (112.941) - All Technical Service Bulletins
2005020003 05/01/2005 Campaign - Harmonic Balancer Pulley Replacement
2005030005 05/01/2005 Campaign - Door Frame Corrosion
P-46_10-19 01/28/2005 Steering - Squeaking Noise Turning Steering Wheel
P-32_25-19 12/30/2004 Suspension - Shock/Strut Replacement Guidelins
P-82_10-419 12/30/2004 Lighting - Condensation in Headlamps
P-30_30-61 12/30/2004 Cruise Control Inoperative
P-67_30-12 12/30/2004 Body - Side Window(s) Open After One-Touch Closing
P-91_10-83 10/13/2004 Interior - Seat Cushion Rocks Makes Cracking Noises
P-27_00-47A 10/11/2004 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 10/08/2004 Body - Scraping Noise From Transmission Tunnel Area
P-82_00-260A 08/25/2004 Audio System - CD's Won't Play or Eject
P-00_45-77 02/17/2004 Interior - Squeaking/Creaking Noise Kit
S-49_10-08 02/01/2004 Exhaust System - Rattling/Hissing/Humming Noises
S-01_30-15 02/01/2004 Engine - Cylinder Wall Damage Assesment
P-40_10-43 01/16/2004 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-18_00-20 12/05/2003 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 12/05/2003 Engine - Oil Sludging/Consumption Diagnosis & Repair
S-18_00-16A 12/01/2003 Gasoline Engine - Oil Sludging
P-83_40-68 10/20/2003 A/C - Unnecessary Blower Motor Replacement
P-82_60-292 09/29/2003 Audio System - Volume Knob Damaged
P-82_85-288 09/12/2003 COMAND(R) System - Unable to Enter New Destination
P-07_07-34 07/24/2003 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 07/22/2003 Navigation System - Inoperative/Erroneous Guidance
P-46_20-12 07/07/2003 Steering - Squeaking Noise
P-82_10-257 06/25/2003 Lighting - Headlamp Bulbs Inoperative
P-82_10-256 06/06/2003 Lighting - Condensation In Fog Lamps
P-20_10-23 05/07/2003 Cooling System - Water Pump Leakage
P-82_70-222 03/21/2003 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 03/07/2003 Body - Windshield/Rear Glass Body Seam Corrosion
P-07_65-31 02/26/2003 Engine - High Oil Consumption
P-80_57-20 02/25/2003 Audio System - RF Interference Explanation
P-82_85-210 11/25/2002 Navigation/GPS System - Various Malfunctions
P-82_62-169B 10/28/2002 Audio System - Various CD Player Malfunctions
P-82_85-198 07/25/2002 COMAND(R) System - No Sound/Whistling
P-46_20-08A 05/29/2002 Power Steering - Horn Like Noises When Turning
P-47_10-16A 02/07/2002 Instruments - Fuel Gauge Inaccuracy
P-47_10-23 02/06/2002 Fuel System - MIL ON/DTC P03XX (Misfire)
P-82_85-182 12/27/2001 COMAND(R) System - Various Malfunctions
P-80_30-13 11/01/2001 Smart Key(R) - Download Time
P-40_10-33A 10/01/2001 Tires - Approved Winter/Summer Tires
P-82_85-171 09/13/2001 COMAND(R) System - Instrument Display Not Centered
P-82_85-170 09/13/2001 COMAND(R) System - Incorrect ETA Calculation Displayed
P-80_57-11 08/29/2001 Ignition System - Electronic Ignition Switch Replacement
P-18_40-14 08/17/2001 Engine Controls - Implausible Oil Level Messages
P-01_00-10 08/14/2001 Alternator - Mounting Bolt Identification/Application
P-91_60-48 08/09/2001 Air Bag System - Side Impact Sensor Replacement
P-82_85-158 08/01/2001 COMAND(R) System - CD Changer Returns to CD Track 1
P-47_31-12 07/01/2001 Emissions, On Board Refueling Vapor Recovery Valve
P-40_10-37 06/01/2001 Wheels/Tires - Short Design Lug Bolts
S-00_00-072 05/01/2001 Emission/VIN Label - Availability
S-05_010A 05/01/2001 Tools - Universal Valve Spring Tool
S-58_091A 05/01/2001 Special Tool - Universal Valve Spring Tool
NHTSA01I005000 04/15/2001 Recall 01I005000: Side Air Bag
S-58_20-93B 04/01/2001 Fender/Interior/Fascia Cover - Availability
200104001 04/01/2001 Recall - Replacement of Side Airbags
200104002 04/01/2001 Recall - Side Airbag Replacement
S-58_00-118 03/01/2001 Engine Oil - Approved Evacuation Equipment
S-40_10-036 02/01/2001 Tires - Maintenance & Inspection
S-00_40-071 02/01/2001 Synthetic Oil Recommendations - For FFS Vehicles
P-88_50-023 02/01/2001 Emergency Trunk Release - Retrofit
S-40_10-034 12/01/2000 Tires - High Performance Tire Storage
S-58_094A 12/01/2000 Chassis/Frame - Dedicated Frame Straightener
S-58_30-103A 12/01/2000 Special Tool - Resistance Spot Welder
S-58_30-115 12/01/2000 Special Tool - Resistance Welder
S-60_00-008A 12/01/2000 Special Tool - Spot Welder
S-60_00-012 12/01/2000 Special Tool - M20 Resistance Welder
S-60_004A 12/01/2000 Body/Frame - Dedicated Straightening Equipment
P-91_60-44 10/01/2000 Rear Door Airbag - Deactivation/Activation
P-40_10-033 09/01/2000 Tires/Snow Chains - Factory Approved Specifications
P-58_20-114 09/01/2000 Front Reinforcement - New Mounting Points & Tool Set
2000100002 08/01/2000 Campaign - Body Sealer Application
DDAF41_40-U-1130AG 07/07/2000 Whistling/Howling From Propshaft When Cold
DDAF42_10-U-6002A 07/07/2000 Selector Lever Blocks
DDAF82_60-U-6008B 07/07/2000 Radio Inoperative
DDAF82_85-U-6000E 07/07/2000 Fault in COMAND Operating and Display System
DDAF97_10-U-4043FU 07/05/2000 Ingress of Water in Luggage Compartment
DDAF82_60-U-1105A 07/05/2000 Interference to Radio After Installing Window Screens
DDAF54_65-U-2000A 07/05/2000 PTS MIL ON For No Apparent Reason
DDAF91_00-U-3010Z 06/22/2000 Electrostatic Charge on Seats
DDAF15_30-U-6405A 06/22/2000 Starter Occasionally Does Not Operate
DDAF42_45-U-8101B 06/22/2000 Electronic Stability Program Fault Code C1142
DDAF42_45-U-8103A 06/22/2000 ESP Fault Code C1120
DDAF82_10-U-2009B 06/22/2000 Main Beam/Low Beam Not Operating
DDAF54_21-U-6008A 06/22/2000 Operational Problem in Upper Control Panel
P-47_30-06 06/01/2000 Evaporative System - Check Engine Lamp (MIL) ON
S-91_40-31A 06/01/2000 Seat Belt - Extensions
P-58-20-111 04/01/2000 Special Tools - Storage, Mounting, and Management
DDAF82_85-U-1002AG 03/20/2000 Tone Settings in Sound System Not Possible
DDAH54_10-P-0001-01A 03/17/2000 Battery Safety Notes
DDAF42_45-U-8001D 03/17/2000 Steering Angle Sensor - DTCs C1140 and C1504 Set
DDAR54_18-P-0100-02A 03/17/2000 Repairing Wiring Harness Using Soldered Terminal
DDAF82_60-U-6008A 03/17/2000 Radio Cannot Be Operated
DDAF82_60-U-6009B 03/02/2000 Operational Problem Radio/Cassette Player
DDAF82_60-U-6700A 03/02/2000 Volume of ``Hands-Free'' System Too Low
P-82_64-121A 03/01/2000 Radio - Voice Activated Cellular Phone/CD Changer
S-82_70-124 02/01/2000 Cellular - StarTAC Portable Telephone Programming
P-82_64-121 02/01/2000 Radio - Cellular Telephone/CD Changer Installation
P-Si-82-64-122 02/01/2000 Radio - Cellular Telephone & CD Changer Installation
P-58_20-110 12/01/1999 Special Tool - Recall, Spring Clamp Plate Set
DDAF40_10-U-2001A 12/01/1999 Increased Tire Wear
DDAF46_10-U-3001AG 12/01/1999 Steering Stiff, Possible Noises
1999080001 12/01/1999 Recall - Infant Restraint/Booster Seat Exchange
DDAF91_60-U-6005A 11/30/1999 Airbag Control Module - DTCs B1310, B1311 Set
DDAF54_20-U-6700A 11/04/1999 Electric Suction Fan Runs All The Time, Ignition OFF
S-Si-00-01-70 10/01/1999 Vehicle - Roadside Assistance Program
DDAF82_10-U-2009A 09/23/1999 High/Low Beams Do Not Function
DDAF07_07-U-6700AV 09/21/1999 Engine, Shakes, Misses, and Dies at Idle
DDAF42_45-U-6200A 09/03/1999 ESP Reacts Too Sensitively at Low Speed Tight Curves
DDAF42_45-U-8100A 09/03/1999 ESP Fault Code C1401 or C1405
DDAF54_30-U-2400A 08/23/1999 Digits in Display Become Darker/Not Legible
DDAF54_21-U-6001A 08/23/1999 Turn Signal Lamp Occasionally Fails to Operate
DDAF82_10-U-6010AU 08/23/1999 Foglamps Not Operating
DDAF77_20-U-1200FG 08/19/1999 Wind Noise at Front of Tilting/Sliding Roof
DDAF72_29-U-6000A 08/18/1999 Failure of Power Window Drive
DDAF91_60-U-6090A 08/18/1999 Airbag ControlModule - DTCs 004, 007 Set
DDAF88_70-U-6000A 08/18/1999 Operating Problem Exterior mirror
DDAF83_30-U-6000A 08/18/1999 Occasional Air Conditioner Failure
DDAF83_40-U-2001A 08/18/1999 EC Lamp ON, Cannot Be Shut OFF
DDAF88_50-U-2003A 08/17/1999 Corrosion at Trunk Lid in Area of Lock Cylinder
DDAF98_10-U-2005A 08/17/1999 Paint Damage to Trunk Lid in Area of Grip
DDAF07_61-U-6000A 08/12/1999 Engine Cannot Be Started
S-99_00-223 06/01/1999 Electrical - Component Locator, Star Finder
DDAF82_10-U-4041AU 05/17/1999 Headlamps/Turn Signals Mist Up or Leaking
DDAF82_10-U-2008A 05/17/1999 Color or Brightness Difference of Headlamps
DDAF82_70-U-1005A 05/03/1999 Telephone Call is Interrupted When Engine Started
DDAF67_30-U-6001A 05/03/1999 Side Window Opens After Closing
P-91_18-39 04/01/1999 Interior - New Style Seat Covers Introduced
DDAF54_30-U-8400A 02/05/1999 Instrument Cluster Indicates Lubrication System Faults
S-58_00-043D 02/01/1999 Special Tools - Inventory List
S-00_00-068 10/01/1998 Computer Software - Y2K Impacts
P-SI-40_30A 08/01/1998 Suspension - New Alignment Tools and Procedures
DDAF42_45-U-8000A 02/11/1998 Steering Angle Sensor, DTCs C1140, C1504, 015, 016, 017
DDAF54_30-U-2107A 04/28/1997 ABS, MIL ON No ABS System Malfunctions
00_053 10/01/1993 Maintenance - Factory Approved Service Products
__________________
raymond-
47º34'N 122º18'W
raymond g- is offline   Reply With Quote
Old 06-21-2010, 08:44 AM   #3
saintz's Avatar
Drives: 2003 CL600
Is it the bearing that is near your ear where the belt comes out of the B pillar? Or is it from the actual mechanism, which I think is down near the floor inside the B pillar? I would use a spray lubricant if it sounds like grinding bearings.
__________________
2003 CL600 - Eurocharged
2009 C300 (wife)
2001 E55 AMG - RENNtech Stage 1, Lorinser (sold)
1999 CLK 320 (sold)
2003 WRX, Stage 4 (sold)
saintz is offline   Reply With Quote
Old 06-21-2010, 03:00 PM   #4
hpilot's Avatar
Drives: 2000 E320
Quote:
Yes, the noise comes from the pillar by my ear. I'll have to see if I can find some place to spray it.
__________________
2000 E320
White
Kenwood DNX 8120
JL 10" 250 Watt Sub
HD Radio
Old 06-21-2010, 10:04 PM   #5
saintz's Avatar
Drives: 2003 CL600
Lithium spray will work. Shoot it around the edges of the wheel that the belt rolls over. The bearings there are noisy.
__________________
2009 C300 (wife)
1999 CLK 320 (sold)
Old 06-25-2010, 02:16 PM   #6
hpilot's Avatar
Drives: 2000 E320
Thanks. I'm sure that is the problem, but how do I get to them?
__________________
2000 E320
White
Kenwood DNX 8120
JL 10" 250 Watt Sub
HD Radio
Old 06-25-2010, 02:59 PM   #7
saintz's Avatar
Drives: 2003 CL600
The belt rolls over a long wheel (or roller) where it attaches to the B pillar near your ear. You can spray lithium grease from a can with a straw attachment. Spray it at the edges of the roller, where it meets the bracket. It should work its way in.
__________________
2009 C300 (wife)
1999 CLK 320 (sold)
Old 01-23-2012, 11:25 AM   #8
freedspeak's Avatar
Drives: 2001 E55 AMG, S54 Mcoupe
Hope this thread is not dead. I have this same issue on my passenger side. I think hpilot was asking if this could be done without removing the B pillar trim? I assume that you meant a straw could be stuck through the opening where the belt comes out in order to reach the rollers? Is that correct?
Thanks!
freedspeak is offline   Reply With Quote
Old 01-23-2012, 11:46 AM   #9
hpilot's Avatar
Drives: 2000 E320
Quote:
Thanks!
I finally just replaced both front seat belts - expensive! The new ones work really well now- and quiet.
__________________
2000 E320
White
Kenwood DNX 8120
JL 10" 250 Watt Sub
HD Radio
Old 01-23-2012, 11:51 AM   #10
RichardM98's Avatar
Drives: 98 Brilliant Silver E320 Wagon
MB frowns on spraying any lubricant on the seat belt mechanisms for fear that the automatic tensioner will fail in an accident.
__________________
Good luck.
RichardM98 is offline   Reply With Quote
Old 01-23-2012, 01:07 PM   #11
freedspeak's Avatar
I may be wrong..I'm a total MB newbie...but I think this is just a simple "roller" in the upper B pillar. If so, I would think the fact that it's not "rolling" smoothly would be more concerning. The actual tensioner would be somewhere else..perhaps at the bottom of the pillar near the floor? Am I wrong? I don't have mine to look at right now...I got it 2 days ago and the wife has already confiscated it! :-)
@hpilot...what is "expensive" if you don't mind me asking..$200...$900...more-less?
Thanks guys!!
Old 01-23-2012, 07:56 PM   #12
RichardM98's Avatar
You have the locations right but any lubricant sprayed on the belt could eventually end up in the tensioner.
__________________
Good luck.
Old 01-25-2012, 03:27 AM   #13
freedspeak's Avatar
Yeh Richard...If I can't get the grease cleanly on the bearings (or axle end?) of that roller, I probably won't try it. That's why I was asking if I should be able to do that with a "straw equipped can" through the opening...without having to undress the B pillar. Do you know that answer? Do you know if there is a way to simply pop the cover off of the height adjuster and expose the roller for a better angle? Do you know how much new belts/rollers cost?
Old 01-25-2012, 10:41 AM   #14
RichardM98's Avatar
As you say if you can deliver the grease to the right spot without getting any on the belt the risk is probably pretty low.
I haven't removed the covering on the B pillar and if raymond suggests it might be difficult it probably is. You might check the DIY stickies on benzworld/W210. There are some video files covering interior trim disassembly and maybe seat belt replacement.
__________________
Good luck.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
09211999, 1120, 2003, angle, bulletin, clk320, consumption, dated, ddaf0707u6700av, dtc, e200, harness, mercedes, oil, radio, sensor, shoulder, steering, v6
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
