Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2003 s500 sport
Check engine light- engine electronics stupid reason(gas cap open)?
__________________
2003 S500 SPORT |
#2 |
Drives: 98 E430
because of the cap being open, the fuel pump isn't able to keep a steady level of volume pressure for the fuel injectors. The car has a Fuel Pressure sensor
#3 |
Drives: 1997 Toyota Tacoma 4x4
It's an emissions reason. By leaving the gas cap open, you're allowing fuel vapors to escape into the atmosphere instead of collecting in the charcoal canister, a huge no-no.
__________________
Dave ASE Master Technician |
#4 |
Drives: E-Class W210, SLK R170, Jetta MKV TDI, MINI Cooper S
A lot of repair shops have made a lot of money off of that same fault. The gas cap seal is an emission standard to check for and will flag the CE light until the fault is corrected. A shop will tell you that your MAF (mass air flow) sensor is bad and charge you $400 to swap it and then replace the gasket on the gas cap. After driving for about 50 miles the code will clear or they clear it with a OBDII code scanner. Thank your girl friend for thinking of the gas cap...
__________________
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors. |
#5 |
Yeah I did thank her
But also thought what a cool way for dealers to make money. After I realised that the open cap was probably a problem I drove again and the code cleared by next morning. thanks
__________________
2003 S500 SPORT |
#6 | |
Re: Thank you girl friend
Quote:
__________________
#7 | |
Quote:
I had that this past winter in my dies... Mind you it was 15-18 degrees Farenheit :-) After about 100 miles the "check engine" went...... |
| Tags |
| 2003, cap, check, cooper, engine, fuel, gas, light, mini, mk5, pressure, replace, s500, sensor, tighten, w163 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
