Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 E320
Transmission fluid under vehicle...
__________________
Richard / E320 2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs Last edited by Richard / E320; 12-30-2010 at 09:20 PM. |
#2 |
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
You need to
buy the special dipstick.Then measure the fluid at operating temp engine running in park.
Look at the electrical connector passenger side of the transmission. Often the cause of the leak and upgraded part and o ring at www.autohausaz.com for 7bucks or so. Warning cap gets taken off and the red security clip need not be replaced. Torque setting is in the trans fluid diy article on www.benzworld.org in the w210 diy section. Happy New Year
__________________
00-02 drivers side heated self dimming mirror glass O2 sensors plug and play 17mm special spark plug boot tool Spring loaded u joint spark plug socket 722.6 transmission dipstick W210 W124 parts Cryo rotors Brake pads F.S. Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz" |
#3 |
Drives: 210 55
6.5 K :S:S:S:S AAAWEESOME!!! congrats on the newer W210 i ever seen..!! pretty cool
Never seen before this models with this FLEX in the exhaust tube! first one to me Fabio Daniel |
#4 | |
Drives: 2001 E320
Quote:
http://www.car-stuff.com/store/?N=42...s+Benz&md=E320 Also found the OES Genuine Automatic Transmission Fill Pipe Cover - 1998-2003 Mercedes Benz E320, which states the same fitment: 722.664 and then 1998-2002 / all sub-models. Would like to verify this is exactly what I need to take a measurement on the transmission fluid level, as I know it's got to be down more than just a couple of ounces. Does the cap currently on the tube just pull off, or is there a clip? Don't want to break it off. EDIT: Got it; for anyone that hasn't removed the cap, the clip has to be broken off and then pushed down first BEFORE you can pull off cap. http://www.car-stuff.com/carparts/me...tings+Page%3A1 Lastly, do you have a part name or number on what you mentioned as commonly failing? Looked around AutohausAZ and Performance Products but didn't really come up with a specific part. Based on price alone, I did find a Auto Trans Conductor Plate; Adapter Plug with O-Rings, part #2035400253. Is this anything close to what you had in mind? http://www.autohausaz.com/search/pro...ductor%20Plate Thanks for your insight and knowledge; I'm kinda surprised that a vehicle with less than 7,000 miles could end up with this type of leak, but it is almost 10-years old and I know better than to ignore it and just top off. Stayed up way too late and found two great threads on the subject: http://www.benzworld.org/forums/w210...ml#post2809739 http://www.benzworld.org/forums/w210...ssion-faq.html For anyone here who has done this plug replacement, the instructions are: "The electric plug is a two part component. The ivory color piece is a twist off mechanism, rotate it probably 3/4 of a turn or so and remove the electric plug, which will stay hanging from its wire harness. Installation is the reverse." - Can anyone clarify in which direction to rotate it?
__________________
Richard / E320 2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs Last edited by Richard / E320; 12-31-2010 at 05:23 AM. |
#5 |
Drives: 98 Brilliant Silver E320 Wagon
It's called a 'dipstick tool' because it is a tool to measure the fluid level but not left in place like the oil dipstick. Plus it's about 6-8" too long.
You shouldn't need a replacement cap for the transmission tube. The cap has an o-ring inside. As long as the o-ring is in good shape the cap will stay on without the 'locking pin'. But since they're only about $1/ea why take any chances getting dirt into the system. If you are unsure of the correct o-rings for the transmission electrical connector just go to the dealer. Measuring the transmission fluid correctly is CRITICAL for these 722.6xx transmissions. It's mentioned elsewhere but 1) the car must be on level ground, 2) the transmission (not just the engine) must be at full operating temperature, 3) only use correct MB fluid (either Part No. A001-989-21-03-10 or No. A001-989-45-03-13) and if you over-fill even slightly drain some out and re-adjust. If your car has the original factory fill and you are only topping off I would suggest using the first part no.
__________________
Good luck. |
#6 |
Twist cw
and pull to remove. Push in and turn cc to install.
Mobil123 or valvoline maxlife are both Nag1/mb722.6 approved fluids so no need to get ripped by the dealer. Happy New Year
__________________
#7 |
MB's factory approved ATF fluids for the 722.6xx have not changed.
See here: http://www.startekinfo.com/StarTek/o...stedDocId=9511
__________________
Good luck. |
#8 |
Nobody said they
changed. The above mentioned fluids are MB spec and approved.MB,febi,shell,valvoline,mobil all make oem spec rated fluid the only difference is you pay $5 a qt for maxlife and get the same fluid.
Must everything be an argument? ![]() Or are you one of the guys that pays 19bucks for the spark plug from the dealer because it has an MB part number when you can get the same plug for 4 bucks at the corner auto store? Lesson for the day, Mercedes part numbers do not mean the part was made by Mercedes. OEM specs are OEM specs and the fluids above meet all of them sans the mb part number you appear to worship
__________________
#9 |
Drives: 2001 E320
Thanks to all for the replies. Due to the holiday, my local dealer was closed today. I called a local import auto parts store and was quoted $12 for the part, but he suggested I call the next nearest M-B dealer. Only 30 miles away, but he wanted $28 for the same part, though he did have it in stock. I don't mind paying a little more, but since I had found the part online for less than $7, the mark-up was more than I thought was fair. Ordered the part from the import parts store, where I know the owner also owns the local M-B store. I didn't buy the transmission fluid yet; I think I'll buy what I need from Mercedes, as I want to ask them to measure the fluid level for me while I top off. At some point I want one of those $40 'measuring tools' but don't really need it immediately.
I really wanted to try and get the part replaced over the weekend, but I've never driven my car in the rain, and it's raining here anyway. I think I'm good to go when the part comes in and if not, I know where to ask. Thanks a lot / have a safe and happy New Year!
__________________
Richard / E320 2001 M-B E320 / Glacier White w/ Java Leather / 18" AMG Style III & Bridgestone Potenza's / H&R Springs |
#10 | |
Super Moderator
Drives: GMC
Quote:
Go with the most recently approved 236.14-specification ATFs. ![]() Fuchs Titan 4134 is ~$10 per liter from RM European with gratis shipping. reference |
#11 |
Drives: 2001 mercedes benz E320
stearing wheel makes noise everytime I turn it, back and fourth.
#12 |
Autohausaz only sells the URO brand for the plug. I have read at Benzworld that it is an inferior part and will leak in a few months. Any advise on this? Oh Lord?
#13 | |
Quote:
__________________
Good luck. |
| Tags |
| 2001, car, changing, color, diy, e320, electrical, fluid, leaking, mb, mercedes, oil, parts, plug, trans, transmission, w210 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
