Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Sponsored by : My Mercedes Parts
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 05-26-2011, 09:53 AM   #1
Drives: 1997 E420
Question W210 Climante Control Unit
I am looking for a new/used Climate Control unit (Part # 210 830 2385 or 210 830 2485). Anyone have any idea where i could get one outside of ebay or the dealer?
To remove this ad, register today or login if you already are registered!
NyJets75 is offline   Reply With Quote
Old 05-26-2011, 11:25 AM   #2
RichardM98's Avatar
Drives: 98 Brilliant Silver E320 Wagon
It would help if you could tell us why you want/need one. Also, I would recommend replacing the unit with the same part number as your old one.
Finally, you old one can be repaired. Try www.beckmanntechnologies.com
__________________
Good luck.
RichardM98 is offline   Reply With Quote
Old 05-26-2011, 11:37 AM   #3
ohlord's Avatar
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
I has one
pm for info.
60 bucks less than the $360 beckmann charges
less than BBA charges to repair
Far far less than the dealer
warranty to boot
__________________
00-02 drivers side heated self dimming mirror glass
O2 sensors plug and play
17mm special spark plug boot tool
Spring loaded u joint spark plug socket
722.6 transmission dipstick
W210 W124 parts
Cryo rotors
Brake pads F.S.
Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz"
ohlord is offline   Reply With Quote
Old 05-26-2011, 11:49 AM   #4
Drives: 1997 E420
I need a new one because the current one is not sending a signal to the A/C compressor to turn on (per the dealer). The A/C will work for about 5 minutes and then the compressor kicks off. I had the entire A/C unit checked and I was told there were no leaks and it is the unit in the car.
Old 05-26-2011, 11:53 AM   #5
ohlord's Avatar
See my reply above
but first does the display work? Have you run the values and errors programs?
If not do so,for if the display works a value in default range for the evap temp sensor could be the issue and dealers often misdiagnose that simple issue and far cheaper tho a bit harder to replace item.
__________________
W210 W124 parts
Cryo rotors
Brake pads F.S.
Old 01-29-2012, 07:47 AM   #6
Drives: mercedes e320
climate control/passenger foglight
I am looking for a used climate control unit and passenger foglight assemably for 2001 e320/w210
almoe is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
17mm, 210, 98, ac, boot, climate, compressor, control, kicks, mercedes, parts, spark, special, tool, unit, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
