Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 E55 AMG - 2001 E320 - 1990 300CE
w210 Motor Mounts
#2 |
it should be no harder than doing it on the V8. There is absolutely no need to remove the exhaust manifold.
__________________
W210: Resonator delete/x-pipe - AMS headers - EC tune W211: Stock w/ cooling mods FOR SALE: VMR V710 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html W211 E63 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html |
#3 | |
It is different!
Quote:
#4 |
Drives: 98 Brilliant Silver E320 Wagon
I replaced mine a while back. I did not need to remove the manifold although I have seen references to that in online DIY posts. The WIS procedure doesn't suggest removing the manifold. However you do need to dismount the A/C compressor and push it a little forward to remove the left MM to the front. There are several DIY's on this repair. Access to the upper mounting bolts is tight. Generally, you need to work by 'braille' with a stubby wrench. Also, you need to raise the engine which means removing or at least detaching the fan shroud.
__________________
Good luck. |
#5 |
Drives: 2001 E430
Shouldn't have to remove the exhaust but the AC does need to be moved as Richard mentioned. As you mentioned the V8 is easier but the V6 doesn't look too bad.
Photos of procedure. http://www.benzworld.org/forums/w210...lacements.html
__________________
Mods•Swain coated Kleemann headers•Metal'cats•Evosport underdrive pulleys•355/328 Brembo BBK•19" Carlsson 1/6 wheels•Carlsson pedals•"Carlsoon" shift knob & lighted sills•burlwood steering wheel & door pulls•H&R cupkit•speedybenz•LED tails•Sprintbooster•Sirius•OEM xenon swap Countermeasures•Hidden Valentine1 with display etched in rearview mirror•Laser Interceptor Awaiting install•Stiegemeier ported HPS gen1 SC•SLR cams•Coolingmist•Wald EX bodykit•VRP intake spacers•Eisenmann race•Quaife |
#6 | |
Thanks for the link!
Quote:
That is a great link with some good pics! Thanks, perhaps I will give it a try. And it does give me some material for battle with the shops over their prices, if it truly is a 2 hour job. I'm sure they quote the removal of the exhaust manifold and use the AC trick to make the profits rise. |
#7 |
Drives: 2002 E320 base sedan, RWD, bone stock
Hi all- I am in the middle of doing this job- and taking out the mounts was np- putting the little ****ers back in- with the heat shields- has been one BIG PITA- does anyone have a trick on doing this? Autohasz came through with good parts/ good price- thanks to all on the forum who recommended them.
I used the online docs, its straight forward- maybe my fault for not marking the shields as they fell out unbolting the mounts. And doing this alone- ugh- two people would maek this so much easier. I just cant catch the thread going thru the heat shield into the new MM. Any help appreciated- and thanks in advance. PS- anyone know the correct way the heat shields are supposed to go in? Thanks again. Last edited by 9918939; 01-09-2012 at 05:48 PM. |
#8 |
PS- anyone know the correct way the heat shields are supposed to go in? Thanks again.[/quote]
I can take pictures of the way they are in on mine, if that will help. Also if you take pictures of your DIY, please post them here. |
#9 | |
Quote:
Also if you take pictures of your DIY, please post them here.[/quote] It sure will- if you can. thanks- check your PM. |
#10 |
Drivers Side Pic
Here are the pics!
#11 |
AWESOME- thanks. Before I catch *****- I thank the forum for the generosity of its members for their time and expertise.
Let 'er rip. I followed the document - engine-mount-diy.pdf - and followed it step by step, and its time consuming but very accurate and detailed and more importantly- correct- I think authored by G-AMG. Finally done- and its smooth as butter- what a difference. Thanks all. Last edited by 9918939; 01-09-2012 at 11:23 PM. |
#12 |
Done! Drives like new!
Okay, finished the job. The link above is terrific for DIY. One suggestion, instead of disconnecting the battery, just cover the starter terminals with some good old duct tape until you are finished.
One other bit of advice: get a stubby 16mm wrench and a ratchet 16mm wrench. I was able to use the ratchet wrench with a pry (wrecking) bar to break and tighten those top bolts (pita and the worst part of the job) and the stubby for the rest of unloosening those stubborn bolts. I also advise loosening the transmission mount while jacking up the engine. All in all, not an easy job but doable and I am just an ordinary wrench. Special thanks to 9918939 for sharing his experience via PM. You can do this and save yourself $600.
#13 |
Old and new motor mounts
Pics of both worn motor mounts and a new Autohasz motor mount on the far right. On to the transmission flush next.
#14 |
I shared my experience:
Changing Transmission Fluid Questions One thing important here is this: Before you start, use your dipstick to measure you existing fluid both at 25C and at 80C. That way you have some assurances that you are putting the correct amount of fluid back into the transmission. When topping off the new fluid, take your time, slow as you go, little by little. Last edited by ESTJ; 01-24-2012 at 08:18 AM. |
#15 |
One other thing, use the MB transmission pan seal, don't go cheap here! This will save you time later.
| Tags |
| 2001, benzworld, dual, e320, e55, exhaust, motor, mount, mounts, muffler, soft, swap, v6, v8, w210 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
