Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: E320 4-Matic Wagon
Who can fix my pixel-display problem?
#2 |
Drives: 2000 E430 Sport
I hate to see people suffer
Wow, almost 200 people took a peek and no one with an answer....
Here you go buddy http://www.bba-reman.com/catalogue/D...ledProduct=391 |
#3 |
Drives: '01 E320, '11 E350C
My mechanic in Northern VA said that they used to know of a place that sold reconditioned ones, but they had such a high failure rate they went out of business. Also he wouldn't do the installation because (as I best recall) only the dealer posessed the right equipment to code it, keep the mileage correct, etc. If you find someone who thinks they can fix it, be sure to check them out very carefully or you may end up back at the dealer undoing any mistakes they might've made. In the end I had to bite the bullet with the dealer, but it's worked fine now for nearly 3 years.
#4 |
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
BBA
http://www.bba-reman.com/content.asp...edes_Dashboard
has a stateside facility they can fix your pixels it won't require version coding your mechanic cost you a lot of money ![]() but that is water 3 years under the bridge ago.....
__________________
00-02 drivers side heated self dimming mirror glass O2 sensors plug and play 17mm special spark plug boot tool Spring loaded u joint spark plug socket 722.6 transmission dipstick W210 W124 parts Cryo rotors Brake pads F.S. Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz" |
#5 |
Drives: 2002 E430 4MATIC
There is an independent in Mundelien called Autobahn Motorworks. His labor rates are similar to dealers but he is much more flexible and won't push work you don't need. Ask for Tony he is the owner.
http://www.autobahnmotors.net/ |
#6 |
Drives: 1997 E420
If need be, you can also buy a used cluster off eBay or elsewhere to use while your correct cluster is repaired. I don't think they are terribly expensive. Looks like you can find them for under $200. Then you can sell it back on eBay again when you get yours fixed! Of course, it probably makes sense to keep your existing cluster with the correct miles. An alternative is to just try to find a cluster with similar miles.
__________________
Search for Mercedes resources at EverythingBenz.com ---- "The overall best use of the E420 is not for commuting to work, impressing our mothers, or making sibs jealous. It's for driving as though you were being chased by dogs. Across Montana." (from a review found online) |
#7 |
Drives: 1997 E420
Sorry -- just to add some thoughts since I just re-read and realized you don't want to DIY. My gut feeling on the easiest way to get it fixed the "right" way is to have a mechanic pull it so you can send it off to BBA (see link above) for repair. Then, either have mechanic keep the car until it comes back or put a used one in on a temp basis so you can use the car. And then of course you have to pay the mechanic to put the repaired cluster back in.
That all may not be worth the cost. So a cheaper option is to find a used one with similar miles on eBay or elsewhere and pay a mechanic to swap it in. If you are going to find one on ebay for temp or perm use, you should first read up on advice for buying the right part from threads on swapping an instrument cluster on this and other forums. Unfortunately, I don't think there is going to be a local place that can fix dead pixels and BBA may be one of the only options for repairing the existing cluster.
__________________
#8 |
I can fix them and have fixed a few including my own.
__________________
W210: Resonator delete/x-pipe - AMS headers - EC tune W211: Stock w/ cooling mods FOR SALE: VMR V710 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html W211 E63 rims - http://mbworld.org/forums/wheels-tir...y-area-ca.html |
| Tags |
| 2000, 2002, benz, chicago, cluster, companies, display, e320, e430, ebay, fix, instrument, mercedes, pixel, repair, trouble |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
