Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Sponsored by : My Mercedes Parts
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-22-2012, 03:28 PM   #1
Drives: E320
1999 E320 ASR & Anti-Lock Brake System Lights Came Up
ASR and Anti-Lock System lights came up while I was driving my 1999 E320 this morning and they stayed on. I lost anti-lock brake ever since. After I stopped the car and pulled the key, the ASR module behind the windshield washer fluid kept running. Do anyone know the cause of the failure and how to fix it? If by the dealer, the cost? Would the battery be drained if the ASR module keep running? Thanks for your help.
Sam
To remove this ad, register today or login if you already are registered!
lucky168 is offline   Reply With Quote
Old 01-23-2012, 05:37 PM   #2
Drives: W210 E300D
If it really is running it most definitely will drain the battery and could possibly damage the ABS(ASR) pump, try pulling the fuses to prevent that, as to troubleshooting you'll need to go to a good Indi shop which specializes in MB or go to the dealer to read out the codes first, then once you know what you're dealing with you can decide what to do next.
CKonstantin is online now   Reply With Quote
Old 01-23-2012, 10:22 PM   #3
Drives: E320
You are spot on. The ABS pump stopped 19 hours later after it drained the battery. I pulled every fuse under the hood but none of it stopped the ABS pump. After the car was jump started, all the error lights were gone and the car was running normal. The car was checked by MB dealer but no error code existed. I was given a $2100 price tag to replace the ABS unit if I wanted to. "No thank you". Do you know where is the fuse of the ABS pump located? Any idea as to how quickly will the problem come up again? Thanks for helping.
Sam
Old 01-24-2012, 06:50 AM   #4
Drives: W210 E300D
It looks like, the main power comes in unfused, so you would have to disconnect the plug of the unit itself.
Good luck.
Old 01-24-2012, 06:47 PM   #5
Drives: E320
Thanks. I am unable to find the plug. Do you know where is it located?
Sam
Old 01-24-2012, 07:06 PM   #6
Drives: W210 E300D
It is big, black and rectangular, located on the ABS/ESR pump, you relly can't miss it. Don't disconnect it unless you absolutely have to, as it may lead to speedometer no longer working, and over malfunctions.
Old 02-07-2012, 11:17 PM   #7
Drives: wdbjf55fxtj020203
Wait a minute the problem is very very simple,, change the damn break light switch ,it is right above the paddle ,, cost $20 at the dealer takes few minutes to replace and your problem will be gone
tmounib is offline   Reply With Quote
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
1999, 2000, 320, anti, asr, bad, brake, brakes, e320, light, lights, lock, locking, mercedes, system, systems
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
