Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Sponsored by : My Mercedes Parts
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-30-2012, 01:44 AM   #1
Drives: E
Retrofiting Xenon OEM Headlights from Halogen OEM
Hey everyone, I am planning on purchasing a pair of used 00-02 Xenon OEM Headlights from an E55 AMG for my 2002 E320; my car is currently fitted with the standard Halogen OEM Headlights. I wanted to know if I am able to swap out my current ones for the optional Xenon OEM Headlights. If possible, will they perform correctly with no error on my dash? Is the installation any different than installing the regular Halogen OEM Headlights? If anyone has any experience or advice, please let me know. Thank you!
To remove this ad, register today or login if you already are registered!
ThanasisKaplani is offline   Reply With Quote
Old 01-30-2012, 03:03 AM   #2
suicidal4life's Avatar
Drives: 2001 E430
I did this on my 2001 and it was plug and play with no error codes. I didn't do the auto leveling feature so I'm not sure how much more work that may be.
__________________
Mods•Swain coated Kleemann headersMetal'catsEvosport underdrive pulleys355/328 Brembo BBK19" Carlsson 1/6 wheelsCarlsson pedals"Carlsoon" shift knob & lighted sillsburlwood steering wheel & door pullsH&R cupkitspeedybenzLED tailsSprintboosterSiriusOEM xenon swap
Countermeasures•Hidden Valentine1 with display etched in rearview mirrorLaser Interceptor
Awaiting install•Stiegemeier ported HPS gen1 SCSLR camsCoolingmistWald EX bodykitVRP intake spacersEisenmann raceQuaife
suicidal4life is offline   Reply With Quote
Old 01-30-2012, 03:10 AM   #3
Drives: E
Sounds great. May I ask: What is the auto-leveling feature?
Old 01-30-2012, 04:36 AM   #4
Drives: 2001 E430
The xenons have motors and sensors to automatically level themselves as you go over bumps. This is to keep them from potentially causing glare to oncoming drivers. I aimed my lights a bit lower then stock to help with this problem.
Old 01-30-2012, 06:54 AM   #5
Drives: W210 E300D
Auto-Leveling is a lot more work, you would need to gut your car to put in the wiring, cause you'll need a sensor in the front suspension as well as one in the rear. Not to mention headlamp-washer retrofit if you'll ever want one.
Other than that it should be the same, not sure about error messages though, I know w211 requires the lights computer to be programmed accordingly, I don't know if same applies to our older cars.
CKonstantin is online now   Reply With Quote
Old 01-30-2012, 01:46 PM   #6
Drives: E
Basically, you guys suggest I just install the headlights, but just skip the installation for the auto-leveling feature; it sounds complicated and expensive. How would I 'tilt' the lights a bit downward as you say suicidal4life? If I didn't, would it be that much of a problem?
Old 01-30-2012, 05:01 PM   #7
Drives: W210 E300D
You still have the two adjusting screws as you do with halogen lights, do a search, or open your cars manual it's all there, really not all that complicated...
Old 01-30-2012, 05:31 PM   #8
Drives: E
I understand. Thank you very much for your help suicidal4life and CKonstantin!
Old 02-01-2012, 02:41 PM   #9
Drives: S430
Since a long time I am trying to put in my s 430 , 2001 Xenon Headlamps . My original are Halogen.Actually, I want every features that the Xenon have . ( motor ,auto leveling or something else that might be ) I asked the Dealer and they told me that I need wiring to install those Lamps and will cost me $ 5000.
Does anybody know, Is the wiring difficult "DIY" ? If someone did it can provide some info ?
Thank you
Twins05 is offline   Reply With Quote
Old 02-01-2012, 03:13 PM   #10
raymond g-'s Avatar
Drives: 99 E320
it's less wiring (almost none) and more mechanical parts (almost all) and nealy impossible to get from dealer w/o a lot of hassle. easier to locate wreck/donor and remove parts i opine
__________________
raymond-
47º34'N 122º18'W
raymond g- is offline   Reply With Quote
Old 02-01-2012, 05:20 PM   #11
Drives: W210 E300D
On the S430 if you have air suspension chances are mos of the hardware's already there. Post your exact year and model(220.xxx) if you know it, and I'll see if I can dig up the procedure.
Old 02-02-2012, 04:28 PM   #12
Drives: S430
Quote:
Yes sir, my s 430 has air suspension, MY 2001 ,220.170. I am planing to install original ones . I found a good deal in Germany , for Bi -Xenon .
Thank you
Old 02-02-2012, 05:58 PM   #13
Drives: W210 E300D
Post
Here's everything you need to know, once everything's installed you'll need to bring it to the dealer or a very good Indi to program them in, to work properly. Good luck.
Old 02-03-2012, 04:26 PM   #14
Drives: S430
Thank you CKonstantin, excellent information. I really appreciated.
__________________
Was ist nicht gut soll man andern, was ist gut kann man besser werden.
Old 02-16-2012, 11:52 PM   #15
Polar Bear's Avatar
Drives: A 805+494 211.026
Is there a WIS guide for 2000-2002 W210 w/washers?
__________________
FS: W211/219 Euro COMAND 7039 $900.00 - PM for details or questions.
Polar Bear is offline   Reply With Quote
Old 02-17-2012, 06:54 PM   #16
Drives: W210 E300D
Post W210 as of 1.7.99(Post Facelift)
Here's the guide excluding Headlamp washer retrofit.
Old 02-17-2012, 10:08 PM   #17
Polar Bear's Avatar
Thank you. It is amazing (and frustrating) how few 210s have these. I can't tell you how many I have skipped online trying to find the right car.
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
210, auto, car, halogen, headlight, headlights, install, leveling, mercedes, mini, oem, retrofit, w210, washer, xenon
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
