Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: MB E320
Cannot turn on ignition
#2 |
Drives: 99 E320
check health of car battery. trickle charge and be sure it's in tip top shape first. report back
__________________
raymond- |
#3 |
Drives: MB E320
The battery was replaced just 4 months ago. It could be that the ignition system is not well charged. I get the battery replaced in a non-MD dealer. How do I check if the ignition system is not fully charged.
#4 |
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
Put it on a 10amp
charger overnight. Key out of ignition and use the underhood charging post POsitive and hook the negative lead of the charger to a clean nut or the upper shaft of the shock tower.
Or you could check current state of battery charge by lifting the rear passenger seat and testing battery charge with a small multimeter. Fully charge battery will show 12.6-12.8 volts.
__________________
00-02 drivers side heated self dimming mirror glass O2 sensors plug and play 17mm special spark plug boot tool Spring loaded u joint spark plug socket 722.6 transmission dipstick W210 W124 parts Cryo rotors Brake pads F.S. Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz" |
| Tags |
| 2001, 320, 99e320, battery, benz, car, class, hear, ignition, key, mercedes, sound, turn, wagon, wont, zzz |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
