Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Home Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors TSB & Recalls
Sponsored by : My Mercedes Parts
Click Here
Welcome to MBWorld.org Forums
submit to reddit
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 01-30-2012, 03:57 PM   #1
siopaolover's Avatar
Drives: 1998 E320
vibration at highway speeds
ever since i had my motor mounts changed at the dealership, my car hasn't been running smoothly. could it be caused by the air filter not being attached properly by mercedes, which caused my car to stall so many times that same day that I almost couldn't make it home?
now between 55-70 mph, the car, the seats, and the console shake. it also idles at around 500 rpm, which i don't remember it doing before i had this problem. is this fixable? i just want it running like how it used to. any suggestions/comments would be appreciated.
To remove this ad, register today or login if you already are registered!
__________________
currently looking for w210 lowering springs...
siopaolover is offline   Reply With Quote
Old 01-30-2012, 05:48 PM   #2
RichardM98's Avatar
Drives: 98 Brilliant Silver E320 Wagon
I don't think the two are related. Generally, motor mount vibration happens at lower rpms such as at idle. Once the rpms rise the spinning flywheel dampens everything out. Of course, it they forgot to properly reassemble the air cleaner box maybe they forgot something else.
A vibration at 50-70 suggests a suspension problem or wheel balance. The front and rear suspension uses a number of rubber bushings which wear out causing vibration. You need to inspect for that. Preferably someone who is familiar with MBs. Any good tire shop can check wheel balance.
500 rpm is a little low but not by much. I think the spec is 575 rpm. To check or adjust requires an SDS at dealer or high end independent.
FYI - anything is fixable if your pockets are DEEP enough.
__________________
Good luck.
RichardM98 is offline   Reply With Quote
Old 02-01-2012, 01:35 PM   #3
Drives: 1998 E320
i'm scared they may have forgotten other things too...
and this may be a suspension problem. i'll look into that
haha and about those deep pockets...
__________________
MBWorld
Mercedes SLR McLaren
Paid Advertisement
submit to reddit
Tags
1998, 320, 4matic, car, e320, higher, highway, loud, speed, speeds, vibrates, vibrating, vibration, vibrations, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld - Contact Us - MBWorld.org Forums - Archive - Top
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright © 2001-2011 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
