Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2001 E430 4matic
'01 E430 4matic, no codes but rough idle
#2 |
Drives: 300E a couple 1994 w124wagon E320 Wagon/,1971MGB Track/Rally, MG Midget Autocross ,2000 E320 wagon.
New air filter
change your spark plugs they are past due.
0w40 mobil synthetic,fleece filter. Check tire pressure correct. if the rear o2's are getting old and sluggish they affect the ecu and the signals to the mass air sensor,so it will help to replace them also.
__________________
00-02 drivers side heated self dimming mirror glass O2 sensors plug and play 17mm special spark plug boot tool Spring loaded u joint spark plug socket 722.6 transmission dipstick W210 W124 parts Cryo rotors Brake pads F.S. Cognomen is in homage to the late great Janis Joplin "Oh lord won't you buy me a Mercedes Benz" |
#3 |
Drives: 98 Brilliant Silver E320 Wagon
I'd vote for checking plugs, plug wires and coils. Sounds like maybe a miss. Probably always there but mostly noticeable at idle. As mentioned plugs should be changed at 100K as well as O2 sensors.
__________________
Good luck. |
#4 |
In addition
to the poor mpg,rough idle without codes for misfires,inspect your motor mounts. If leaking they will cause idle shake at lights and in neutral.
__________________
#5 |
I got an oil changed at MB dealer, dont know why they used Valvoline instead of Mobil 1 0W40 as factory reccomended, about the 2 rear O2 sensors, Actually I do not feel good to replace for now bc of budget limitlity, but I will replace air filter and clean the MAF then if nothing beter I will go to spark plugs and wires
#6 |
#7 |
thank you for the Idea, is the cost for replace wires is not too rough ? I have very small budget due to the job has been down for now
#8 |
Drives: things with and without wheels
If you are on a tight budget then hold off on the wires and do the spark plugs.
When you pull the plugs inspect them, they might tell you what is going on in the combustion chamber.(misfire or rich condition) |
#9 | |
Quote:
If you were getting codes for a misfire you could move the plug wires and/or the coils to a different cylinder and see if the codes follow. With a tight budget maybe the best solution would be to get the car scanned with SDS at dealer or indy. Even though you will have to pay for that you will avoid installing parts which may not help.
__________________
Good luck. |
#10 |
| Tags |
| 2001, 4matic, 94, cables, change, codes, e320, e430, forum, idle, idles, mbworld, mercedes, oil, plug, rough, shakes, spark |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
