Sign in using an external account
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2000 E320 Wagon
Transmission drops out of gear
#2 |
Drives: 1999 e320
Same issue on my 99 E320. First, check the fluid level & status. There are two reasons for the trans slipping into neutral
1) if there is a serious issue internally, the computer will throw a code and go to neutral to prevent any more damage.(2) if there is no code, it is a mechanical issue such as a bad neutral switch or control box.The latter is about $100 to fix. Otherwise you are SOL. |
#3 |
Wound up having this repaired the next day. Transmission fluid was low, and something in the transmission has shorted out. Cost a lot more than $200 to fix, unfortunately.
| Tags |
| amg, c320, coming, cornering, dropping, drops, e55, fast, fix, gear, mercedes, neutral, signs, slips, transmission, w210 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
