Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-17-2012, 01:45 AM   #1
desired_speeds's Avatar
Drives: 02 E55 & 04 E55
Send a message via AIM to desired_speeds
DIY: Plastic seat trim creaking fix
Ever since I got the car, the plastic seat trim next to the door on the seat has always creaked. It was a minor annoyance, but it eventually got on my nerves. This weekend I removed the seat and fixed it using some thin felt (moleskin for door panels). I cut pieces out and stuck it to the seat frame where the plastic contacted. The result is no more creaking!
My next project is to fix the rattle that the headrests make. My w210 has quite a few rattles. I'm not sure if its just mine or is it all 210s. Does anybody else's car have a bunch of rattles?
Few pics on where I placed the felt:
Click the image to open in full size.
Basically all these baffles that stick up from the plastic trim is what caused the creaking when it rubbed against the metal seat frame.
On the other hand, I hit 140k mi last week. Still runs like a champ and I'm loving every second of it!
To remove this ad, register today or login if you already are registered!
__________________
W210 | W211
FOR SALE:
(2) two w211 OEM heat exchangers. will take best offer!
desired_speeds is online now   Reply With Quote
Old 04-17-2012, 03:04 AM   #2
raymond g-'s Avatar
Drives: 99 E320
adding a seat TSB to the thread in case someone else has similar noise
__________________
raymond-
47º34'N 122º18'W
raymond g- is offline   Reply With Quote
Old 04-17-2012, 10:10 PM   #3
mistertonyn's Avatar
Drives: 1999 E320 & 2008 S550 Designo
Nice work on the fixes.
My e320 creaks when I accelerate, brake and I think maybe turning as well.
I also feel like the seat moves about 1/4" or so....and thinking perhaps the seat frame is cracked or broken.
It sounds more like a metal creaking and not a plastic creaking...but who knows...you may have solve my problem.
How easy to remove the seat and put back? any special tools required?
thanks
__________________
mistertonyn is offline   Reply With Quote
Old 04-18-2012, 12:06 AM   #4
raymond g-'s Avatar
Drives: 99 E320
if you dilly-dally, it may take 5-10 mins. it's that simple. even the power
connectors are easy as they only fit into one possible socket. still, it wouldn't
hurt to label them as you unplug.
i seem to recall that it may be easier to remove the 2 rear anchor bolts first before
the front 2 bolts, then unplugging the electricals.
requires external torx #15 to unfasten the 4 bolts, each of which are behind
small plastic valances. good to mark which end up or you'll stare at it trying to
figure how to fit back into the rails.
__________________
raymond-
47º34'N 122º18'W
Old 04-18-2012, 04:09 PM   #5
Musikmann's Avatar
Drives: 2001 E320 RWD - Brilliant Silver/Ash: 99,000+
Send a message via ICQ to Musikmann
Once in a long while I hear the infamous thump in the sunroof area, other than that, none.
__________________
Mercedes Benz - Das beste oder nichts!
Musikmann is offline   Reply With Quote
Old 04-18-2012, 09:09 PM   #6
Thanks Raymond
You have the same year as mine...did you have the same creaking problem? and if so how did you fix yours?
__________________
Old 04-18-2012, 11:38 PM   #7
Quote:
over really bad roads I get a few loud thunks from the headliner. It's bearable on a daily basis though. My center console creaks/shifter area creaks also. I gotta get around to that next.
__________________
W210 | W211
FOR SALE:
Old 04-19-2012, 12:03 AM   #8
raymond g-'s Avatar
Drives: 99 E320
Quote:
i dont recall any annoying squeaks and creaks. but be aware that I also swapped
out all of the seats and replaced them with Designo multi-contour seats from a
wrecked E55. i wanted more lumbar support for my back and the air bladders
did the trick. i used a pillow for a few months then was alerted that the E55
seats were available.
__________________
raymond-
47º34'N 122º18'W
Old 04-19-2012, 12:06 AM   #9
raymond g-'s Avatar
Drives: 99 E320
headliner chatter. this is what i did (overview):
  • removed hand rails above rear doors,
  • pulled out door gasket
  • removed C pillar cabin liner
  • popped off rear dome light
  • carefully lowered headliner and slid in a sheet of 1" bubble wrap from each side
  • sewed it back up
very quiet now
__________________
raymond-
47º34'N 122º18'W
Old 04-19-2012, 12:15 AM   #10
  • sewed it back up
very quiet now
so I basically insert the bubble wrap between the headliner and the back of the sunroof assembly? I will try that this weekend along with pad up the passenger side seat trim that was rattling today. Thanks!
__________________
W210 | W211
FOR SALE:
Old 04-19-2012, 01:09 AM   #11
raymond g-'s Avatar
Drives: 99 E320
try this thread. note some pics i attached to post #74
__________________
raymond-
47º34'N 122º18'W
Old 04-22-2012, 05:09 AM   #12
Holbay's Avatar
Drives: Mercedes E300 Turbodiesel
The creaking from the front seats in my W210 E300 has been driving me nuts now i know how to fix it thanks mate..George
Holbay is offline   Reply With Quote
Tags
2001, car, creaky, door, e320, e55, fix, frame, pillar, plastic, pop, posts, seat, sunroof, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
