Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > E-Class (W210)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-26-2012, 01:37 PM   #1
Drives: 1997 E420 and 1990 560 SEL
Michael McFearin
1997 E420 Multiple Missfires
Mt 1997 E420 is running poorly, rough and loss of power, also poor fuel millage and the smell of raw fuel in the exhaust. I started having these problems at 154K so I had the 150K work done at an indy. Plugs, boots, and all 4 O2 sensors replaced.
I am at 168K now and all problems have returned. Codes show cylinder 2,3, and 8 missfire, multiple missfires, and rear back O2 sensor failure.
I I found all this returning odd but I did use an indy I had never used before, generally I do all my own work after warrenty but got lazzy. So I pulled and replaced all plugs (copper ones spaced correctly now) the indy had installed platnum plugs in an amazing aray of poor gap settings. I also replaced the 3 boots. The O2 sensor erros I figured was just do to raw fual because of the missfires so I have not replaced it yet.
Unfortunatly this didn't correct anything so I went ahead and replaced all 3 ignition coils. This also has not solved anything. I can't see an O2 sensor causing all this and while I didn't get a code for it this seams to me the next thing to replace is the MAF. Ideas?
To remove this ad, register today or login if you already are registered!
mmcfearin is offline   Reply With Quote
Old 04-26-2012, 05:40 PM   #2
Drives: 1999 E300TD
How old are you wires?? Do you have live data capability on your scanner??
Plutoe is online now   Reply With Quote
Old 04-27-2012, 05:49 AM   #3
Drives: Mercedes-Benzes: 2005 ML500, 2002 E320 4-Matic, 1993 300E, 1994 E320, AND 1999 C230 KOMPRESSOR
Check fuel pressure...sound like a fuel problem to me!
__________________
I'M A FACTORY-TRAINED MERCEDES-BENZ MASTER SYSTEMS TECHNICIAN, ASE (AUTOMOTIVE SERVICE OF EXCELLENCE) MASTER AUTOMOBILE TECHNICIAN, BOSCH MASTER TECHNICIAN, MECP (MOBILE ELECTRONICS CERTIFIED PROFESSIONALS) MASTER TECHNICIAN, AND A L1 ASE & BOSCH ADVANCED ENGINE PERFORMANCE SPECIALIST WITH A MASTER'S IN BUSINESS ADMINISTRATION.
MASTERBENZ is offline   Reply With Quote
Old 04-27-2012, 08:12 AM   #4
Michael McFearin
Unfortunatly I don't have live capabilities on my scanner, I am looking at finding a new scanner preferable one that links to a laptop.
I have not thought of fuel presure issues, is there a test I can do for that?
The wires to the coils are original.
Thanks for your time guys.
Old 04-27-2012, 12:44 PM   #5
Drives: 1999 E300TD
Although thoughtful, fuel pressure testing is not easy without the actual values and tools for the locations to be tested.
I would at least start to test the condition of the wires. However I do not have the values. Get a new one and check it's value. Rail and injector fuel pressure issues will normally produce faults. I would also check my coolant sensor----use your AC value test to check that! Just don't get suckered in to a new MAF!!
Old 05-06-2012, 11:41 AM   #6
Drives: e320
I had the same issue spent over $800 trying to fix at indy's with no luck to finally be the wires.try taking one of the wires on a cylinder that is not complaining with one that does; and see if the issue follows.
erashid is offline   Reply With Quote
Tags
1997, 210, code, e200, e420, fix, maf, major, mercedes, misfire, misfiring, missfire, problem, sensor, sulfur, w210
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
