Sign in using an external account
| E-Class (W210) 1995-2002: E 200, E 220D, E 240, E 290TD, E 300TD, E 200, E 240, E 280, E 320, E 420, E 430 (Wagon, Touring, 4Matic)
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
#2 |
Drives: 2001 E320 wagon
Googleit!
Type in viseeo bluetooth. $225 -250 usd
__________________
'01 E320 WagonOne extends one's limits ONLY by exceeding them... Fortune cookie |
#3 |
Drives: 01 E320
There are many posts on this board about this if you do a search. forget about using the phone feature in your vehicle, that is way dated. There are some add ons but I,d suggest replacing the stereo unit with a nice receiver with bluetooth. I just put in a nice Kenwood that was about $170. it will give you other features like streaming bluetooth audio, in dash cd, usb interface to ipod or other devices plus a huge sound quality improvement. If you sell the car you can throw the old radio back in
#4 |
Yes Bucs23, I did look at that but the problem is that I do not have a cradel and it totally cost about $500 to $800 (including the viseeo bluetooth+overseas shipping charge+the nokia 6210 cradel)in order for me to just talk on the phone while driving and so I dont think I will go with that option. But as 01BlackE320 said I might try that option because it is a hellava lot cheaper, but my question to 01BlackE320 is that every mechanic shop I went to told me that it is waste to install some other stereo because it decreases the sound quality. I don't if that's true or not! And they also said that rewiring is hard because the original is all optic wires and so I wanted to know the exact Kenwood you put in and how did you put it in? Thanks you guys very much.
#5 |
Drives: 01 E320
I installed the Kenwood Excelon KDC-X696. It's $169 at Crutchfield and they include all the adapters that you need to install it. Their web site will tell you exactly what will work in your car.
I have a 2001 E320 sedan with the Boze option. I can only talk about that setup because I do not know what your car has installed. This stereo has 4v preamp output which feeds the existing Boze amp and speakers. The audio is much improved from what it was, particularly with the radio which sounded pretty lousy before. What I lose is the steering wheel controls and the CD changer in the trunk, neither of which I cared about. I had it professionally installed, which included running the microphone up near the headliner for the bluetooth phone. It's a relatively easy install that is not to time consuming or expensive. If your car does not have a separate amp, it would be wired using the amp that is built into the stereo which is still pretty good. Again, Crutchfield.com will tell you what you need and you can call them with additional questions |
#6 |
I have 1999 E430 with the premium Bose speakers and I was also looking at crutchfield.com and I was looking at the cheap $100 ones but if you say that the ken wood ones are great then I would buy that. Did you buy that professional installation kit with it for $99? Thanks again.
#7 |
I too don't care about losing the cd player because all my songs are in my iPod touch and so I will connect my iPod and then I can forget about burning cd's for my car. Man thank you so much. You have no idea of the pain I go through by listening to the same songs over and over and over again. I now tell the order of all the songs, it is that bad
#8 | |
Drives: 01 E320
Quote:
It"s a popular model. You can probably get it anywhere. The cheaper models usually have 2v preamp output which will not work as well. plus you want Bluetooth, good luck Last edited by 01BlackE320; 05-01-2012 at 09:27 PM. Reason: adding |
#9 |
Drives: W210 E55
Do you mean you want to use the factory hands-free bluetooth system in the car? If yes, this can be done. If you want to use the factory PHONE, this can no longer be done AFAIK.
#10 |
Let me see it
Any pics to see what the NEW set up look like?
__________________
#11 |
Drives: E320
I found out recently that my Garmin has a SD card that will hold about 1000 songs or more and will transmit on any FM freq. It solved all my problems. GPS, integrated phone and plenty of tunes. Just set it up that my preset 0 is the Garmin. You do lose some volume but 99% of the time the music is clear and your incoming calls come right over your speakers. Just a thought. Worked for me for a fraction of the cost
| Tags |
| 1999, 430, 99, benz, button, e430, installation, mercedes, phone, prices, radio, set, soundtrack, stereo, tel |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
