E200k w210 loss of power
Old 05-17-2012, 07:16 PM
Pk51's Avatar
Mercedes e200k w210
I have e200 kompresser it has loss of power comes and goes I think may maf sensor it not working to good what I have noticed is if I do the trottle reset I think that what it is the car resume power for a period of time verys can anyone help and does the camstaft adjuster have anything to do with powerless thanks
Old 05-19-2012, 10:55 AM
MoNd3sTo7's Avatar
W210 E200K
I have the same problem.. Last week my E200k suddenly loss power (just like turbo lag) when i drive but after i restart everthing went back to normal.. who can tell me what happen? Someone tell me i need to change the fual filter???
Old 06-28-2012, 07:47 AM
Pk51's Avatar
Mercedes e200k w210
I have checked the maf and it Is covered in oil so I have clean it using electronic component cleaner it was ok for a about 3 weeks but has lost power again don't want to change the maf yet until I work out where the oil is coming from.
Old 07-05-2012, 08:28 AM
MoNd3sTo7's Avatar
W210 E200K
ok let me know what you have find?
Old 07-05-2012, 05:39 PM
Pk51's Avatar
Mercedes e200k w210
I have got power back I think what is that my car has LPG convention on it I had new LPG filters put in and the power came back it was poor on petrol I think when I ran it on gas the ecu thought there was a problem so it would not run poor on petrol and LPG but I have a new problem I think my kompresser bearing is gone the car engine has a veining noise from it i know the the kompressor do abit louder then non kompressors but mine is loud don't know what to do want to try to replace bearing but need instructions and still getting oil in the air mass sensor I read a post say that there are to breather valves just under the inlet manifold which get blocked can course this but need th remove inlet manifold to get to them another big job this can also course power loss
Old 07-05-2012, 05:43 PM
Pk51's Avatar
Mercedes e200k w210
I think it is a cheap option change the fuel filter and put some injector clean in too
Old 07-12-2012, 09:37 AM
MoNd3sTo7's Avatar
W210 E200K
i went to the dealer to have my car check.. they found out that the fuild is leak to the transmission's control unit.. everything cost me to repair is B$8000++ that's a lot of money.. US$1 = BN$1.29
Old 05-16-2016, 09:25 AM
mercedeskpu820's Avatar
mercedes benz E200 kompressor w211
Hi there guys... I have a MB E200 Kompressor and I was told that I must change the timing belt kit every 100.000 kilometers... is this true???
Will appreciated any assistance.
Thank you
Old 06-12-2016, 01:31 PM
Natsheh's Avatar
W210 E200K
W210 E200K maf
I have problem in my E200K its have a loud wire noes and the engine shake and you can smelt a gasoline and after 2 minutes all that gone all that came when you start after 2 to 4 days you can watch the video i filmed and what best engine oil i but a elfe 10w-40 i need help. And where can I find the obd bort?
https://youtu.be/G-AOBuI9hzM
Quick Reply: E200k w210 loss of power
