Rear diff noise when lift off the gas?
Old 12-07-2012, 12:19 AM
craigndee's Avatar
slk 230
Hiya guys. Have a 00 E320 4 Matic. when I'm driving the car on he gas there is no noise or problem. When I'm driving and lift off the gas to coast I have a noise coming from the rear of the car. Sounds like maybe a diff noise but hard to tell. It has a groan like sound that goes away as soon as I get back on the gas. Not real loud but loud enough to be bothersome/worrysome. Any ideas? Rear diff? Driveshaft U joint? Thanks for ideas guys.
Old 12-07-2012, 09:02 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Why seattle sam the issue----put the car on a lift and your mechanic will quickly find the source------without that my guess is the rear ash try is full or you have too much beer in the trunk!!
Old 12-07-2012, 12:34 PM
craigndee's Avatar
slk 230
Okay!
Ok, as per your advice I emptied the rear ashtray. I also drank all the beer that was in the trunk as well. I guess I'll try swapping the muffler pump from front to rear, changing the taillight fluid has not seemed to help at all, and I know my door hinge flabber gear is centered on the lower control brake. Just trying to get some ideas.
Old 12-07-2012, 01:54 PM
Plutoe's Avatar
1999 E300TD
Ideas are good, however just think of all the turning surfaces behind the engine. That coupled with the fact that sound is transmitted(travels) throughout the car.
At this point you know all those turning surfaces, but which one is making the noise, from my vantage point a credible answer to your question would be impossible without listining to the duplicated sound and pinpointing the suspected area.
Old 12-07-2012, 09:11 PM
craigndee's Avatar
slk 230
Wheel bearing?
I'm starting to wonder if it can be a wheel bearing. Sounds like a droning noise. Wondering if letting off the gas unloads the bearing and causes the noise. Gonna put not up and get a better look tomorrow. Thanks
Old 01-16-2015, 10:06 AM
jay m's Avatar
2002 E320 4matic & 2003 E320,
Hey craigndee, what did you find out about the noise? I'm getting it too. Thanks, jay
Old 01-16-2015, 10:17 AM
craigndee's Avatar
slk 230
Noise from rear
Hi guys, After getting the car on the lift I found that my problem was a rear wheel bearing. Replaced both sides and problem was solved. Good luck to all.
Old 01-16-2015, 10:27 AM
jay m's Avatar
Thanks craigndee!, I'll check it out. Any tips on determining the wheel bearing are bad? Jay
Old 01-16-2015, 11:30 AM
craigndee's Avatar
slk 230
tips. Maybe...
Get the car on a lift and manually spin the rear wheels. Listen for any creaking and popping noises even very light ones. You can also grab the wheel at 3 and 9oclock with your hands and see if it has any wiggle or play in it. Hope that helps.
Old 01-24-2015, 12:52 AM
adam15's Avatar
2000 Mercedes E320 4Matic
I'm having the same issue on my 2000 e320, how much did it cost you to replace the rear wheel bearings with parts and labour?
Quick Reply: Rear diff noise when lift off the gas?
