FlatlineEF9's W210 Rebuild thread
#103
Finally got some decent pics. Took a vid of the exhaust too just startup and revving. Will post that later. First pics since I got the front lip re-sprayed
#104
Current mods
Brabus Lip kit
Brabus Monoblock VI 18x8.5 and 18x9.5
Michelin Pilot Super sport tires
#1 Pads
Ksport Coils
Koni Yellow Dampers
Blacked out grille
LED tails
32% Tint
15" Rockford power sub
2000W ample amp
Body color corner lights
Cats Deleted
Brabus Exhaust
Brabus steering wheel
Facelift Airbag
Brembo Slotted Brake discs
Stoptech Pads
Brabus Shiftknob
Brabus Doorpins
Brabus Flat Hood badge
Brabus Lip kit
#1 Pads
Ksport Coils
Koni Yellow Dampers
Blacked out grille
LED tails
32% Tint
2000W ample amp
Cats Deleted
Brabus Exhaust
Facelift Airbag
Stoptech Pads
Brabus Shiftknob
Brabus Doorpins
#106
00 C200 & 00 C55 & 06 SLK55
Flatline,
WaaaaW, great color with Fabulous lowering..,
prefer if you can remove the Star emblem & put a Brabus emblem in trunk(as far as you have a Brabus touch)....
ZAYED,,
ZAYED,,
#109
Its on my list of things. Currently im going to do the front brakes and the double din first. Stay tuned
#110
1997 E320
She is beautiful...on the lower valence of the rear bumper , did you have to make the cut on the lip to make the tips stick out or was it part of the brabus lip kit?
#111
Part of the brabus kit. It was made for use with that exhaust so I knew the engineering would be perfect, and it is
#112
Picked up OEM E55 taillights. Was hard to find genuine MB ones like this. Big thanks to Siopaolover for the bulb plugs
#114
Update. With the install of the tails and new LED parking lights, im now finally "LAMP ERROR" FREE! Ive had some sort of stupid lamp error for the past 7 years. So nice to not have to press "r" every time I turn on my lights. Also don't have to explain whats defective when people ask about it
#115
More mods. Finally got around to doing the BBK.
These parts have been collecting dust under my bed for the past 6 months or so. Half of me was lazy and the other half was scared they might not work (leaky seal, stuck piston, etc etc.) The rotors are C55amg 345mm rotors. Brake calipers are 2002 S55 amg. Pads are OEM Mercedes from the 2002 S55. The factory line bolted right in to the back of the caliper with no leaks/issues. The caliper needed 3 washers to sit correctly on the rotor with the pads having equal spacing on both sides. Only small issues were the brake pad sensor doesn't clip in, so I just pinched the wire behind one of the tabs of the bracket holding the pads in and put the sensor in the correct place. Its holding fine. Other little well known issue is the rotor retaining screw doesn't line up right, but the lug nuts/wheel will hold it on just fine.
Final product. The car is filthy right now so ill get some shots this weekend at hot import nights.
Edit: The calipers came black originally on the 2002 S55, but I had them sanded down and painted iridium silver by my friend.
#117
More mods yesterday. Took a crack at the double din.
Got the radio and climate controls out...easy part haha.
At this point I have the center console out and the ashtray. Still getting the upper wood, glovebox and ac vent out.
Pic of the different wood trims.
Finally got that bugger out. Not fun...not easy. I wouldn't like to do that again lol.
Putting the new cage in was easy compared to getting the old one out. I had a hell of a time. Slowly put everything back and only got hung up a couple times where I dropped screws and broke my ashtray cover. Total time was 4 hours with those snags...30 mins of it was fixing the ashtray cover, it wouldn't close
Final product. Going to put in a double din dvd player tomorrow.
It turned out well and the dash is just as strong as it was before...I had no idea that the plastic cage is such an essential part of dash integrity. Will post more pics tomorrow after I put the dvd player in. Aloha.
#118
2001 E430, 2002 ML55
More mods yesterday. Took a crack at the double din. Got the radio and climate controls out...easy part haha. At this point I have the center console out and the ashtray. Still getting the upper wood, glovebox and ac vent out. Pic of the different wood trims. Finally got that bugger out. Not fun...not easy. I wouldn't like to do that again lol. Putting the new cage in was easy compared to getting the old one out. I had a hell of a time. Slowly put everything back and only got hung up a couple times where I dropped screws and broke my ashtray cover. Total time was 4 hours with those snags...30 mins of it was fixing the ashtray cover, it wouldn't close Final product. Going to put in a double din dvd player tomorrow. It turned out well and the dash is just as strong as it was before...I had no idea that the plastic cage is such an essential part of dash integrity. Will post more pics tomorrow after I put the dvd player in. Aloha.
So when upgrading to the double din, one needs to change the plastic cage behind the wood? Do you have a part number for this by any chance? I can't find it in EPC or WIS
#119
Thanks Serb. 2106890916 is the part number for the cage. Yes you do need the plastic cage for the OEM wood. Im sure you can do something custom with some fiberglass or something...but I wanted to keep the OEM structure and OEM look.
#120
Final product. I adjusted the lighting of the unit to match the amber of the rest of the dash. Looks good at night. Tested Bluetooth, ipod, USB thumb drive, DVD and CD...all work flawlessly.
#122
Thanks BIGJZ74. It came with the kenwood unit, along with a metal mounting cage that I was able to use for inside the plastic cage I installed.
#124
1998 Mercedes E-320
