REST Button - again
1 in-car temp
2 temp outside
3 heater core temp, left
4 heater core temp, right
5 evaporator core temp
6 engine coolant temp
7 refrigerant pressure (in bars)
8 refrigerant temp
9 not used
10 blower control voltage in range .8 - 6V (max)
11 air pollution sensor
12 sun sensor
20 control current of aux fan
21 engine RPM (x 100)
22 vehicle speed, km/h
23 terminal 58d battery charge, percent
24 battery voltage
40 software status register
41 hardware status register
2 temp outside
8 refrigerant temp
9 not used
12 sun sensor
24 battery voltage
98 W210 Advantgarde
Mic: so you know your speed in KM/H!
E-Klasse, I guess 22s pretty much useless when I already have a KMH speedo (also can't understand why RPM is repeated there).
What (and how) does #11: "Air polution sensor" tell me?
98 W210 Advantgarde
Press and hold the REST button on your AC for 12+ secs. These codes will come out on ur AC readout. Press auto on right and left to navigate. Codes tell u info per E-Klasse list - got it?
Originally posted by michakaveli
E-Klasse -
What is item #22 used for?
23 terminal 58d battery charge, percent... Percentage of the capacity of the battery that is charged?
E-Klasse -
98 W210 Advantgarde
Originally posted by paomien
i wish they had realtime gas mileage readings like bmw has on their hidden menus
Location: Long Island, NY / Mississauga, Ontario / Changhua, Taiwan
11 S550V4
Originally posted by Whitey
Shouldn't there be one on the digital readout on the dash? I haven't checked but would expect so.
24 battery voltage
They read close to the same thing but at different points in the circuit. If you had a load on the circuit or an electrical problem the numbers would be greatly different. If all is well, they should be close to the same.
24 battery voltage
Checked my 2000 320 and it reads mph in the "rest" readout. At 40 mph on the speedometer, it read 40 on this display. I also have a 99 CLK but I have not checked its readout recently.
My 23 reads "0" with the engine running Does this mean its not working?
At one point mine read "00" but usually "100" . I don't know how to interpret these values...
There might be different software levels from year to year or in Euro vs US models to account for different readings. With mine the 2 voltage readings are less than 0.5 volts different and my speed reading matches the kmH value on my speedometer. According to all of the posts there are some that match MPH or the second voltage reading is % charge. Strange...
98 W210 Advantgarde
E-Klasse, which two voltage readings?
Pls correct me if I'm wrong , does the % on 23 represent the % of the battery's power level i.e. a fully charged battery should read "100" and if its "0" it means its dead?
BTW, where are you getting all this techno. info from?
Cheers.
Cheers.
